Results 1 to 10 of 17
Thread: {B4206} Use O2 With Open Loop Commanded Fuel Table
Hybrid View
    Default {B4206} Use O2 With Open Loop Commanded Fuel Table
    I auto tuned my VE (BEN's == 1.00+/-0.01) and am still in auto ve tuning mode, and I enabled B4206, and now what do I do...?
    My log (I'll post a picture later) shows STFT's active, and the WBO AFR not always following the commanded AFR, it follows it at larger throttle positions;
    ...hmmm... I'm still thinking out loud ... any comments...?
    Oct 2004
    So was/is your intention to go back into Closed Loop? In the V3 Custom OS the B4206 cal is not present. It sounds like you are attempting to get the equivalent of the Semi-Open Loop?
    Could it be that the O2 switch points are off? I'm kinda thinking out loud as well
    Andrew
    EFILive Crew
    My intention was to see what B4206 does, but I'm not sure what to look for.
    My question would be "How does B4206 work...?"
    It uses STFT to trim to the OLFA B3605 table, right...?
    How far from EQ 1.00 can B3605 be and have B4206 be able to trim...?
    (Log is on my laptop, have to wait to 'til I wake up tp post pic).
    I didn't just wake up now, I've been running some 240V wiring for our dryer...
    Here's images of B4206 in action...
    I should have logged HO2SV11 and HO2SV21...
    I'm still playing around with this to see what it does.
    Default More pictures of this mornings log of B4206
    It seems the actual AFR is "short term closed loop" trimmed to 14.63 below some throttle position, regardless of commanded AFR;
    and above that throttle position the mode is "short term open loop", and the actual AFR follows the B3605 OLFA table (the commanded AFR);
    so where is the tuning parameter for the "B4206 short term closed/open loop" throttle position; I don't see it anywhere...?
    Is this how it works...?
    May 2007
    interestingly I am looking for info on this, did you find anything out? I'm swapping from Custom OS3 to 12225074. I've got b4205 set to standard so sftf should activate anyway and ltft are also enabled just dont know if I should activate b4206
    Quote Originally Posted by stigmundfreud
    No, I didn't have time to dig any deeper, and then I switched to COS5...
  1. Commanded Fuel when in open loop and PE modifier based on RPM
    By Thumper in forum Gen III V8 Specific
    Last Post: September 6th, 2008, 09:47 PM
  2. commanded closed loop fuel ratio LS2
    By ssvolvo in forum General (Petrol, Gas, Ethanol)
    Last Post: July 8th, 2008, 07:04 AM
  3. Semi-Open Loop: what's the fuel economy like?
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2007, 12:28 PM
  4. Commanded Open Loop AFR (B3605) Question?
    By fyi in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 09:54 AM
  5. Open Loop Fuel Economy Results
    By oztracktuning in forum Custom Operating Systems
    Last Post: March 12th, 2006, 11:38 PM
