Results 1 to 4 of 4
Thread: Relearn turbo sensor
    Sep 2013
    Default Relearn turbo sensor
    Hi, I replaced my turbo vain position sensor on my lbz and need to relearn it, I am new to the v2 still, would anyone be able to help me and explain how to go through that procedure on how to relearn it? Thanks
    Junior Member Donovan's Avatar
    Sep 2007
    Why are you sure that you need to learn it? Do you have a P003A? On my truck it stopped coding after I dropped in a new turbo.
    Checkout the "VNT Offset Learn" dvt in the scan tool. I think that is what it does. I haven't tested it though. According to the GM tech manual you need to be at idle and up to temp in order to do the learn procedure.
    I have also read that you can flash a new tune in which will zero the turbo learned position as well which will cause the procedure to occur. I have not tested this.
    E35A/A40 + DSP5
    Aug 2017
    I have a p003a code and I just put a stealth 64 on my lbz. Iv tried a lot ot get rid of it but flashing it is my next option after putting the new vps on. I'll post my updates.
    Feb 2018
    What did you end up finding out. I just installed a stealth 64 and mine is throwing a po3a code and won
  1. Turbo Vane Sensor
    By chaserose in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 8th, 2013, 02:15 AM
  2. Crank sensor relearn 97 chevy truck
    By Gregs in forum General
    Last Post: March 29th, 2010, 02:21 AM
  3. 02 sensor locaion for my ls turbo nova
    By 73 Nova Guy in forum Gen IV V8 Specific
    Last Post: November 26th, 2009, 03:59 AM
  4. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
  5. E38 Crank Position Sensor Relearn
    By hapnermw in forum Gen IV V8 Specific
    Last Post: May 2nd, 2009, 04:58 PM
