Just finishing up my build, 03 Silverado SS, AWD T56, forged LQ9 9:1 CR, precision 7475 turbo.
Since I'm still breaking the engine in, I have the wastegate spring pulled. Engine has maybe an hour on it and is still noticeably burning oil (rings seating i hope)
Anyway I did the COS3 2 bar upgrade, my PCM was a 12579405 OS so I loaded the applicable COS, no problems there.
Had a bad 2 bar MAP sensor (read 4.7V KOEO), just got the new one in and the 2 bar is now scaled.
Others assisted me with siemens 80 motoron data, I swapped them in today and no issues. They idle identical to my stockers and before i cranked up the VE table they were idling at 14.7 AFR.
I got my wideband (LC1) communicating to EFILive via Serial, that aspect seems to be working great thus far.
I started going through the AutoVE tutorial today, my goal for the truck is Open Loop Speed Density. Maybe later on I'll go semi open loop but for now open loop seems to be the easiest for me to understand.
The problem is that about 40-50% TPS engine under load the turbo spools anyway. Not a big deal, 2-3psi according to my boost controller (not hooked up) and I have adequate fueling to handle this. The problem is that it seems like when it transitions from the main VE table to the boost VE table the engine stumbles and misses.
My question is this: Could this stumble/miss be attributed to timing or VE tuning? I have the boost VE timing table set to 0 so it's not pulling any away and I haven't touched the stock timing tables. Also I cranked up the VE table values 15%, had a preliminary boost VE table in there but the 105kpa cells match in both tables.
Could someone please take a look and give me some suggestions?
COS_2Bar_15PercentIncreaseAutoVE.tun
COS3_2bar_drivearound.efi
Many thanks
