Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Throttle Cracker - No CPP due to being a Holden PCM
    Jan 2013
    Default Throttle Cracker - No CPP due to being a Holden PCM
    I've got some low speed surge on a mildly cam'd LS1 (M6 - manual).
    I've rear several thread and understand how the TC & TF might help with this.
    However I've logged the IAC_TC_DMA & IAC_TF_DMA on both a 1221256 & COS5 OS the TC PID is showing basically zero adjustments. The TF is adding air to match any changes I make to tables.
    As I don't have a CPP switch or the wiring as I'm using a Holden based wiring loom & PCM. Maybe an automatic OS might get the TC tables working again?
    Any other suggestions would be appreciated.
    Jan 2013
    I think I'll try the 12225074 OS which was originally on my PCM.
    I have a choice of two files one from an auto and one from a manual. Is there actually a difference in the software? Both are 12225074.
    Is there a way to add a CPP switch...?
    Jan 2013
    I will check at the weekend as I'm not near the car but there may not be a pin on my connector. On the Holden autos that pin is Blue/White and connects to PRNDL A.
    So I may be able to add a pin and use the 1221256 OS but I've got a custom converted car with a bias pedal box and it's a lot more hassle than finding an OS that will work without one. I'll try the Holden OS on the PCM and post back the result.
    Jan 2013
    OK so I copied over all the tables from 1221256 LS1B 512K PCM to my original Monaro (Holden/HSV) 12225074 LS1B 512K tune which took a while!
    I reprogrammed the PCM with the new OS and went for a drive. Immediately I could see the IAC_TC_DMA PID was logging consistent values and my surge has 99% gone. I have some transmission slop so it will never be perfect and there may still be some fine tuning but I now have the Cracker tales working without a CPP clutch switch.
    Maybe this is worth a sticky?
    Only downside is the LTFTs have shifted a bit so it probably needs a few CALC.VET etc. runs to get them close again.
    OK, stickied (and I'll work it into the collected links thread).
    Jul 2003
    I can actually change in the cal to eliminate the CPP.
    Feb 2006
    Quote Originally Posted by Highlander View Post
    Interested how to do this as my retrofit also doesn't have a CPP - can you share?
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    Jul 2003
    No, cannot, but I can fix it... send email to desaintpreux at gmail dot com.
    Feb 2006
    Mail sent
    Jim
  1. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  2. Throttle cracker question
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 6th, 2009, 04:26 PM
  3. throttle cracker
    By Boost in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2007, 09:53 PM
  4. Throttle Cracker P/N
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 27th, 2007, 02:32 PM
  5. Dang Throttle Cracker
    By tazinhawaii in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2006, 02:58 PM
