The CPP is disabled in this calibration.
Is this a manual car?
Hi, Yes mine is manual
2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
All wrapped up in a 2000Lb AC Cobra Replica
So you need me to enable the CPP switch?
There are 2 modes for the switch... 1 to ground 2 to ign... which is it you want?
Throttle Cracker is disabled...
you have b4311 b4312 maxed out.... what cam is in this car?
What transmission do you have? Gear ratios????
Hi Christian, I have no CPP switch fitted in my car, as long as the ECU isn't "expecting" an input then all is good (I have a feeling that from what you've said above that may already be the case....in which case I apologise for wasting your time)
Jim
No, no problem.. its disabled
but the test is running for CPP OBD2 wise.... I can disable that too.
