What gear ratios are in your transmission? where did you get this cal from? did you do a segment swap? does your tranny have the temperature sensor?
Try the file I sent you... has the CCP OBD2 test disabled to be sure... The surging was caused for different reasons... all which i have fixed (hopefully, every car is different).
Basically you had idle closed loop control enabled 100% of the time... that is a completely different routine.
Sorry,
you have closed loop disabled... any reason why?
Still.. my changes should fix your surging issues while coasting in neutral.
2.66:1 1.78:1 1.30:1 1.00:1 0.74:1 0.50:1
Original cal was 2000 Camaro, then upgraded to COS3 (did it a while back so can't remember how, but followed the tutorial),
Tranny temp sensor....nope
CL disabled as I have zero O2 sensors fitted (or cats or anything else vaguely emissions related).
I'll go try the file you sent
Huge thanks
Jim
2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
All wrapped up in a 2000Lb AC Cobra Replica
Email Resent... disabled O2s Permanently.. disabled heater routines. Disabled O2 Tests... Disabled pretty much any use of the O2 sensors. (it should free some headroom)
