Results 1 to 5 of 5
Thread: LMM DSP-5 p0102
    Apr 2012
    Default LMM DSP-5 p0102
    I'm having some trouble with an LMM I've tuned with a dsp-5. It keeps throwing the p0102 code even though I have that code set for not reported no mil. The code sets at low cruising RPM's. The guy didn't have any problems with this before with his H&S Black Max on it. The EGR is not blocked but it is tuned so its not active.
    Could an egr that's slightly open cause this problem?
    2008 GMC 2500 CC 4x4 LMM DSP-5, Transgo Jr,Converter Flow Valve,Sun Coast Triple Disc,4'' Exhaust,Lift pump,Edge Evo for the gauges.
    2006 Chevy 2500 CC 4x4 LBZ Bone stock w/mild tuning.
    2002 Chevy 2500 CC 4x4 LB7 DSP-5, Precision ML Converter,TransGo & a few more things,4'' Exhaust,Lift pump,Autometer
    South of the Rio Grande
    Mar 2009
    I get that one quite a bit with the BOSCH ECM's. I turn it off and ignore it. It will still show up on an all code scan, but not an emissions scan. Others refer to it as a ghost code. Don't feel bad as you're not alone with it.
    Apr 2012
    Quote Originally Posted by THEFERMANATOR View Post
    If it was a soft code I would ignore it. It is actually setting the check engine light even though the code is set to not report no mil. I've tried it several different ways and the light still comes on. I've tuned roughly 30 LMM's and this is the only one I've had an issue with. It looks like I will be putting a dsp-2 in for him.
    Apr 2012
    Well the DSP-2 did the same thing. We had flashed it with the DSP-2 for a test and it didn't set the check enging light so we went ahead and put the switch in. The light came on after we drove it for 15-20 minutes. It set the dtc when the engine is at low rpm's. I've double checked everything I can think of and can't find anything wrong with the calibration or the intake system.
    Has anyone ever tried a finger stick on an LMM?
    Apr 2012
    It turns out that the p0102 was not responsible for turning the MIL on. It was a p0571 cruise control circuit "brake switch " that was setting the check engine light.
    Before I tuned the truck the first time I read that code out with the V2, cleared the code and flashed the truck. The cruise was intermittent but checking for DTC's with the V2 only pulled up the p0102.
    I had the scan tool running yesterday doing some data logging and read the code when it popped the light on and the P0571 was the only code shown.
    I've learned a valuable lesson from this. I will be checking codes from both scan tool and V2. I figured the V2 was getting all of them when I selected the mfg all for checking DTC's.
  1. V2 DSP Switching on LBZ/LMM
    By Cougar281 in forum FlashScan V2
    Last Post: November 14th, 2011, 08:53 AM
  2. DSP for LMM and LBZ
    By johnasara in forum General (Diesel)
    Last Post: December 23rd, 2009, 02:31 AM
  3. LMM DSP switch
    By GL4662 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 19th, 2009, 07:32 AM
  4. DSP-5 for LMM???
    By flyguy_17 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 15th, 2008, 05:42 AM
