The N/A monitor means it is not supported...
if this did not report as ready then this adds to the number of not-ready monitors and the OBDII test would fail if you exceed 1 or 2 not-ready.
Each monitor has 2 state parameters: supported state, readiness state...
previous versions of EFILive software/firmware tried to combine both of those together
(which is why you would see N/A);
the newer software/firmware separates those 2 state parameters out...
to see this use the V2 BBL feature to view the monitor supported states and readiness states.
Also, use a 3rd party scanner to see this (all the not-supported monitors report as ready).
I don't have the CARB doc's (too much $$$), but Paul (the software/firmware developer) is following those doc's closely, which is why he made the recent V2 BBL firmware change.
