Results 1 to 10 of 11
Thread: V8 Scan tool Help.....
    Apr 2007
    Default V8 Scan tool Help.....
    I have been using 7.5 and did a firmware upgrade now I can't use the scan tool in V7.5. I get V8 to find the car computer, but that is it I cannot seem to get it to connect. How can I log now? Help please....
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    V8 Scan tool is not ready yet, just the charts page is functional. You need to use V7.5 Scan tool for logging. Why cant you use the V7.5 Scan too? Did you make sure to update both V7.5 and V8 to the latest version?
    Junior Member 55chevdelray's Avatar
    Mar 2009
    I'm getting the same problem. I have uninstalled V8, and tried to use V7 but gives me an error saying incompatible interface, then tells me to install V8.
    Brian
    EFI Live V2
    55 Chevy with C4 Corvette Suspension
    LS376/480 (E38) and 6L90(T43)
    My Project: http://www.picturetrail.com/sfx/albu...r/55chevdelray
    zapp168 and 55chevdelray:
    first, what are your current V2 firmware/bootblock versions...?
    if you haven't already, download/install V7/V8 from here: Update-Sep-25-2013
    then carefully follow this: Setting-up-a-FSV2-from-scratch
    Mar 2009
    boot block 2.07.06
    firmware 2.07.49
    Brian
    EFI Live V2
    Apr 2007
    Firmware: 2.07.49
    Bootblock: 2.07.06
    V8 2.2.234
    V7.5.7 build 242
    And I get the same message as 55chevdelray incompatible interface. I will look at the tutorial you have listed. Thank you
    Mar 2009
    Which parts of this do I need to do? I already have calibrations I want to flash to the ECM/TCM.
    Brian
    EFI Live V2
    Mar 2009
    UPDATE: I went and tried to flash a calibration to the ECM and it worked this time. The only thing I did that I think fixed it was reloading the software. Odd...
    Brian
    EFI Live V2
    Quote Originally Posted by 55chevdelray View Post
    These parts:
    - start V8 Scan & Tune (S&T),
    - goto F5: BBX,
    - save to file Options.txt,
    - click Program All (accessed via downarrow next to Program button), wait for it to finish,
    Ok, cool good job.
  1. Replies: 22
    Last Post: June 20th, 2013, 03:45 AM
  2. Scan tool match tune tool?
    By zapp168 in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 05:27 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Fit to Scan Tool/Tune Tool
    By limited cv8r in forum General
    Last Post: March 3rd, 2007, 06:10 AM
