Results 1 to 5 of 5
Thread: t/h and turbo brake?
    Sep 2013
    Default t/h and turbo brake?
    hello guys im new too the efi and have been playing around with mine a little. I want to make my turbo brake work only when using the t/h mode. ive read some of the other posts but its still not quit clear too me yet, I see how it works while driving normal but not in t/h mode I guess im overlooking something.
    Lifetime Member tokymon's Avatar
    Apr 2008
    you can not set it so it only works in tow/haul i set mine so that when cruising (rpm range) it is not on but in the higher rpm it is (ie. above 2400)
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
    Mar 2009
    Set it so it only comes in above 2200 or so and you will be fine. For most normal driving the converter will be unlocked when deceling above 2200 RPM's, so you will not feel it. Plus you don't get much of a turbo brake below about 2400, so it isn't a big deal 98% of the time.
    Sep 2013
    ok cool thanks. so too make sure im right you adjust tables b2210,2212,2214 target/desired, and b2222,2223,2224 max position tables , from 2200 rpm 90% @0mm3 all the way up.
    Mar 2014
    so did those settings end up working out for you?
  1. Turbo Brake Function?
    By KB3MMX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 18th, 2013, 12:27 PM
  2. Turbo brake
    By jkf in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 3rd, 2011, 01:35 AM
  3. LBZ Turbo brake
    By amhobby in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 21st, 2010, 05:28 AM
  4. Turbo brake
    By maxxflip in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2009, 10:39 AM
  5. turbo brake switch??????
    By justin123 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 13th, 2009, 02:14 PM
