Im pretty sure they were crossed from the stock tune.. I'll muk with them and post it back up.
97 Auto Shift.xls
That should be better now
Just got the new tranny wired up last night drive shaft installed and all...
Everything has gone pretty great with the new tranny I've got it all dialed in where i like it.. just need to finish fixing the rest of my engine troubles. and get my front lift on lol.
Thanks for all of the help and support fellas.
The truck has come a long way the transmission runs pretty great now I had a shuddering issue in 4th but have not seen it in a few days since some readjustments of the TCC engagement tables
My have the stall and just about everything worked out with it the engine needs to be removed and oil leak fixed and the cylinder re-honed because the piston rings never seated properly.
These things are just par for the course except for being ripped off I suppose
I know this thread is old but I was searching for something and ran across this.Do not use Dex 6 or any other synthetic trans fluid in a 700r or 4l60e, I had best results with Valvoline Dex III trans fluid non synthetic.
Did you get to fix this?
Yup... I sure did..
That transmission from MAD Dog Transmissions was a peice of junk.... Didnt even have clips on the clutch packs when we tore it down... What a mess.
Now the trucks sitting because the rings werent right. Im gonna pull it and have a new set of rings put in... Then do a Calc VE and love life again.
