Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 109
Thread: TCC releasing at crusing speeds with light throttle
  1. #21
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Funny thing about it is that it doesnt do it while things are warming up it only does it once its up to temp... 5~10 min of driving and it wont stay locked.
    shot a video audio is all messed up because apparently the exhaust resonates at exactly the correct frequency as the mic on my phone.... And youtube is being a tard about letting me get the link to my unlisted video.
    Im feathering the throttle there.
    I think i can feel it slipping before it comes out.
  2. #22
    Mar 2011
    More data from the log
    From my newbish understanding the info below indicates that the TCC is indeed slipping even though its in locked status.
    LOG
    Final LOG of the night.efi
    Data Points
Name:	Locked TCC slip then returning to normal.png
ID:	15983Click image for larger version.
  3. #23
    When that happens, also look at the pids TCCDC, TIS, TOS.
    It's not as simple as believing the TCCSLIP pid... I found for some OS's it is accurate while for others it is not.
  4. #24
    Mar 2011
    Event Begin
Name:	TCC Event.png
    Event End
Name:	TCC Event End.png
    Im no expert but it looks like its the TCC the input and output RPM stay the same threw the whole thing.
    What does that mean? Is something wrong with the tranny or is it just the TCC?
  5. #25
    I'm thinking it over...
  6. #26
    Feb 2012
    The difference between RPM and TIS should be converter slip.
    In 'Event Begin' you can see that RPM & converter slip rise together, while TIS & VSS don't really move - I'd attribute that to TCC clutch slip.
  7. #27
    Mar 2011
    Quote Originally Posted by darcy View Post
    So what are we looking at a New TC because of the TCC (Torque Converter Clutch)?
    I upped the slip pressure increase per second but its not done anything.
    I just dont understand why it only does that when its hot. Is it not mantaining pressure? A new TC wouldnt fix that.
    Could the fluid be getting used somewhere else causing a low fluid scenario?
    Is this a side effect of lac of fluid?
    Possibly should I over fill the tranny and see if its a lac of fluid. (Heard that has negative effects)
    Im going to check the fluids after it does it the first time and see what ive got. My truck is lifted in the back though so i guess i should check the fluid on a hill to get a realistic reading lol.
    Thanks for the help. Any ideas would be appreciated at this point. I cant drive it to work or anywhere out of town and it acting like that.
  8. #28
    Does it only do it when hot...?
    I agree, overfill with 1 quart and try again, but every few miles check the dipstick for signs of aeration/bubbles.
    When you changed the filter, did you correctly install the new seal and the new filter...?
  9. #29
    Mar 2011
    Only does it once it's hot
  10. #30
    Mar 2011
    Its a new tranny. Built by a tranny shop. So I dont know..
    I checked the fluid after running it was a little on the low side... But still on the stick... couple bubbles but no foam. added 1/2 a quart and then hit the road...
    Its getting to the point it wont hold TCC lockup at all at this point. Starts slipping out no more than it locks up.
    Fluid was a little yellowish but I wouldnt call it burnt.
  1. Light Throttle Surging
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: July 28th, 2013, 03:49 PM
  2. Trans hits 4th hard with light/no throttle, fine with moderate throttle
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 4th, 2013, 12:10 PM
  3. TCC slips at light throttle
    By rumblebox in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 5th, 2012, 05:13 AM
  4. light throttle surge.
    By activity233 in forum Gen III V8 Specific
    Last Post: November 25th, 2012, 12:14 PM
  5. Replies: 23
    Last Post: May 23rd, 2010, 08:38 PM
