Page 11 of 11 FirstFirst ... 91011
Results 101 to 109 of 109
Thread: TCC releasing at crusing speeds with light throttle
  1. #101
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Im pretty sure they were crossed from the stock tune.. I'll muk with them and post it back up.
  2. #102
    Mar 2011
    97 Auto Shift.xls
    That should be better now
  3. #103
    Mar 2011
    Just got the new tranny wired up last night drive shaft installed and all...
  4. #104
    Mar 2011
    Everything has gone pretty great with the new tranny I've got it all dialed in where i like it.. just need to finish fixing the rest of my engine troubles. and get my front lift on lol.
    Thanks for all of the help and support fellas.
  5. #105
    No worries... let us know how you go.
  6. #106
    Mar 2011
    The truck has come a long way the transmission runs pretty great now I had a shuddering issue in 4th but have not seen it in a few days since some readjustments of the TCC engagement tables
    My have the stall and just about everything worked out with it the engine needs to be removed and oil leak fixed and the cylinder re-honed because the piston rings never seated properly.
    These things are just par for the course except for being ripped off I suppose
  7. #107
    Lifetime Member driver456's Avatar
    I know this thread is old but I was searching for something and ran across this.Do not use Dex 6 or any other synthetic trans fluid in a 700r or 4l60e, I had best results with Valvoline Dex III trans fluid non synthetic.
  8. #108
    Jul 2003
    Did you get to fix this?
  9. #109
    Mar 2011
    Yup... I sure did..
    That transmission from MAD Dog Transmissions was a peice of junk.... Didnt even have clips on the clutch packs when we tore it down... What a mess.
    Now the trucks sitting because the rings werent right. Im gonna pull it and have a new set of rings put in... Then do a Calc VE and love life again.
  1. Light Throttle Surging
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: July 28th, 2013, 03:49 PM
  2. Trans hits 4th hard with light/no throttle, fine with moderate throttle
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 4th, 2013, 12:10 PM
  3. TCC slips at light throttle
    By rumblebox in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 5th, 2012, 05:13 AM
  4. light throttle surge.
    By activity233 in forum Gen III V8 Specific
    Last Post: November 25th, 2012, 12:14 PM
  5. Replies: 23
    Last Post: May 23rd, 2010, 08:38 PM
