Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 109
Thread: TCC releasing at crusing speeds with light throttle
  1. #91
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Quote Originally Posted by hog View Post
    Zeroing tables eliminates Adaptive Shifting.
    Dexron 6 atf.
    peace
    Hog
    Redline D6 ATF
    Opinions?
  2. #92
    Mar 2011
    Whats teh deal with TCC lockup during shift
    Not real happy about having to redo my shift pressures... spent alot of time on them getting them where i wanted... better safe than sorry though.
  3. #93
    I'm happy using M1 and Valvoline synthetics, but that is purely subjective.
  4. #94
    WOT shifting with stock TCC applied typically damages the TCC.
    Aftermarket multi-plate TCC's can handle this ok.
    But, either way, unlocking during an upshift allows the torque converter to help the engine (allows engine RPM to stay up in the cam's torque range, and multiplies torque going into the trans).
  5. #95
    Post screenshots of your shift pressure tables.
  6. #96
    Mar 2011
    The performance ones are what i used to have... the blue lines are the new values from the Stock Camero tune
Name:	3-4 Shift.png
Name:	2-3 Shift.png
Name:	1-2 Shift.png
  7. #97
    You should use the blue ones.
  8. #98
    Aug 2010
    +1 on Joecar's comments.
    The high pressure settings were to assist with diagnosing the issue with the previous transmission rebuild, and could contribute to harsh shifts in a properly operating transmission.
  9. #99
    Mar 2011
    Nice ive returned those tables to stock...
    Re worked my 3rd gear TCC using the spread sheet provided here on the forum... If you could have a look and see what you guys think.
    97 Auto Shift.xls
    Thanks.
    I'll likeldy be picking up the tranny sometime next week.... hopefully be installing it by the weekend.
  10. #100
    The basic rule is: the curves cannot cross.
    i.e.:
    - the shift curves (upshift and downshift collectively) cannot cross,
    - the TCC curves (apply and release collectectively) cannot cross;
    in the xls you posted, these do not follow the basic rule:
    - the 4->3 downshift curve crosses under the 2->3 upshift curve,
    - the 3->2 downshift curve crosses under the 1->2 upshift curve,
    - the TCC 4th release curve crosses above the TCC 4th apply curve;
    If you un-cross those your upshifts/downshifts and TCC apply/release will be more predictable.
  1. Light Throttle Surging
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: July 28th, 2013, 03:49 PM
  2. Trans hits 4th hard with light/no throttle, fine with moderate throttle
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 4th, 2013, 12:10 PM
  3. TCC slips at light throttle
    By rumblebox in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 5th, 2012, 05:13 AM
  4. light throttle surge.
    By activity233 in forum Gen III V8 Specific
    Last Post: November 25th, 2012, 12:14 PM
  5. Replies: 23
    Last Post: May 23rd, 2010, 08:38 PM
