Results 1 to 7 of 7
Thread: Autocal Error Code 322
    Oct 2013
    Default Autocal Error Code 322
    I'm trying to flash a tune and the autocal goes through its process. After a few seconds at 0% it shows error code 322. I'm doing everything correctly as far as I know. Anyone have this issue and/or know what I'm doing wrong?
    Autocal is has been updated.
    I've gone as far as removing the radio and info fuse as idicated that htose may cause interference.
    03 Yukon 6.0L
    any insight would be apprecicated.
    Fitz
    Your tuner (who provided the AutoCal) should be providing support.
    Oct 2013
    I've contacted them just waiting for a reply. Does that mean it's a tune problem not the device?
    Oct 2013
    $0322
    Conditions Not Correct or Request Sequence Error ($22)
    A request was made by FlashScan or AutoCal and the controller was not able or ready to handle the request.
    Retry the operation.
    Contact EFILive if this error persists.
    Nov 2005
    Tuners use AutoCal in different ways, because of the multiple ways the device can be setup and managed with their customer base, it is impossible for EFILive to offer you support without knowing those exact setup details. As an end user, typically you are unable to provide us with the setup details we require, which is why you are referred back to the Tuner for support.
    The first step in our support process is ensuring the software versions, firmware and bootblock from both devices are aligned (the AutoCal you are having trouble with, and the FlashScan V2 that was used to create your tunes), and are they same versions as our current pre-release (Sept 25)? It's unlikely that you would be able to answer those questions on behalf of your tuner.
    Then we move onto how the tuner setup the AutoCal. Did you read the controller and email your tuner your base file? if you did, did you experience any problems with reading your vehicle? Or did the tuner just send you a file to flash? If they just sent you a file to flash, what was it based off? Do the operating system and segment details match?, again many of these questions are best answered by your tuner.
    Your tuner is likely to ask you other questions too - like had the vehicle been tuned previously, can you read your file, or read/clear codes as part of their trouble shooting process. If you have time, you could perhaps start to go through those things so you are prepared for when your tuner does get back to you.
    Cheers
    Cindy
    Jun 2011
    I just experienced this same code when flashing directly through my V2!
    Lee
    Reiff Diesel
    Nov 2005
    Lee, are you asking for assistance or making a statement?
    If you need assistance, you need to provide vehicle and controller details, along with V7 and V8 version details, firmware and bootblock details, details of the process followed that generated your error code along with other relevant details; ie has the truck previously been tuned by your V2, or another programmer and given the present conditions in the USA if you were flashing outside in an unheated environment what was the temperature (note: temperature related issues wouldn't throw this code, but FlashScan isn't rated to operate in the extreme cold many locations in the USA are presently experiencing)
    Cheers
    Cindy
  1. Autocal Error $06FF
    By Mike@Vengeance in forum AutoCal
    Last Post: July 30th, 2013, 01:49 AM
  2. Code 0536 tune file not registerd to autocal device
    By manny sts v in forum AutoCal
    Last Post: January 10th, 2013, 11:47 AM
  3. Replies: 0
    Last Post: April 17th, 2012, 12:42 AM
  4. error code $11
    By chance cobb in forum Cummins 5.9L
    Last Post: January 2nd, 2012, 03:26 PM
  5. Autocal Error Code $0524
    By bax in forum AutoCal
    Last Post: November 23rd, 2010, 12:14 PM
