Does Anyone know the Bit Descriptions for the ECM.MINJSTAT_F PID? I am getting a defuel around 3000 RPM, and the Counts goes from 7 to 15 when it happens. Then it goes back to 7 (Bit 4 goes low) fuels, and then repeats. Its currently a CSP tune, but had the same issue with a stock OS (Currently OS 55450202).
I posted the tune (very unrefined at the moment) and logs if anyone cares to take a gander. For some reason the .pld v8 files are not allowed, so the log isn't trimmed to the offending portion. Tune 1 is bone stock and 5 has almost all the limiters removed or maxed, and both do the same thing (just different power levels of course).
Truck is an 07 Mega Auto, with a 6.7 lower / 5.9 head and electronics. It had a Smarty SSR on it, but I started with a VIN Corrected clean file, and it has shown the same symptoms since I started. I've turned off every limiter I can find so far, looking for the culprit. I don't want to just max them all out and go for broke, I'd like to narrow it down and modify the one thats causing the issue.
The truck also has a CoPilot, not sure if that could affect it at all?
I am thinking about trying a new OS to see if that makes a difference, but I don't want to start over completely if I don't have to.
Thanks in advance for looking. -Joe
