I have been using 7.5 and did a firmware upgrade now I can't use the scan tool in V7.5. I get V8 to find the car computer, but that is it I cannot seem to get it to connect. How can I log now? Help please....
98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
V8 Scan tool is not ready yet, just the charts page is functional. You need to use V7.5 Scan tool for logging. Why cant you use the V7.5 Scan too? Did you make sure to update both V7.5 and V8 to the latest version?
I'm getting the same problem. I have uninstalled V8, and tried to use V7 but gives me an error saying incompatible interface, then tells me to install V8.
Brian
EFI Live V2
55 Chevy with C4 Corvette Suspension
LS376/480 (E38) and 6L90(T43)
My Project: http://www.picturetrail.com/sfx/albu...r/55chevdelray
zapp168 and 55chevdelray:
first, what are your current V2 firmware/bootblock versions...?
if you haven't already, download/install V7/V8 from here: Update-Sep-25-2013
then carefully follow this: Setting-up-a-FSV2-from-scratch
boot block 2.07.06
firmware 2.07.49
Brian
EFI Live V2
Firmware: 2.07.49
Bootblock: 2.07.06
V8 2.2.234
V7.5.7 build 242
And I get the same message as 55chevdelray incompatible interface. I will look at the tutorial you have listed. Thank you
Brian
EFI Live V2
UPDATE: I went and tried to flash a calibration to the ECM and it worked this time. The only thing I did that I think fixed it was reloading the software. Odd...
Brian
EFI Live V2
