Results 1 to 4 of 4
Thread: Advanced Camshaft Timing What needs to be changed in tune???
    May 2011
    Default Advanced Camshaft Timing What needs to be changed in tune???
    I have a 2006 Hummer H2 with 6.0L LQ4 block, LS1B in my tuner selection. I have installed a new timing chain
    and I advanced the camshaft position 2 degrees, equals 4 degrees crank advance, to get more low end power.
    What modifications to my tune do I need to accomplish to make this work as good as it can?
    Thankyou for any professional help.......
    Jul 2012
    You will need to purchase an external wideband and recalibrate your VE table, along with ensure your MAF sensor is correct. There are tutorials explaining how to do that.
    Not sure what else might need to be done
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Jan 2013
    Idle maps will be the other tables requiring some massaging which will also most likely require some timing adjustments in the High/Low and base maps
    May 2011
    Default Thankyou
    Quote Originally Posted by Wheelz View Post
    Yes I know that basic tuning needs to be accomplished but the cam position sensor has been
    advanced 2 degrees and I'm not sure what is exactly controlled by that reading (injectors,ignition, timing advance,etc..)
    I know that the crank position sensor and the cam position sensor input data to the PCM but whathappens when you disturb
    the original relationship I dont know...... I'm guessing I need to compensate for the shift somehow..... Am I thinking correctly??
  1. Adjusting Pilot Timing when Base Timing is changed?
    By koolky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 20th, 2014, 02:47 PM
  2. Has the timing bias been changed?
    By hpi_jeep in forum Cummins 5.9L
    Last Post: January 22nd, 2012, 04:20 PM
  3. Timing curve too slow? Needs to be advanced faster?
    By onegonewild in forum Gen III V8 Specific
    Last Post: June 25th, 2009, 08:10 AM
  4. Confused...Timing tables changed
    By MMLMM in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 7th, 2009, 02:43 PM
  5. Can the timing tables 'x' axis be changed
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: May 1st, 2007, 07:54 PM
