Results 1 to 2 of 2
Thread: Tunning issue with 4094 avnt
    Oct 2013
    Default Tunning issue with 4094 avnt
    I own a 2007.5 lmm and have a stage 2 4094 avnt turbo with Idaho robs tunes and keep getting a p0029 under boost code and truck keeps going in power reduced mode was wondering if anyone has had same issue and what would be the fix for this issue? Truck also seems to shift to quick like gets up to 6th gear really fast wondering if that's normal or is my shift points need to be adjusted the truck is on 35 inch tires would that have a affected on the shifting to quickly? If someone could give some input that would be great
    Member koolky's Avatar
    Aug 2013
    My first recommendation would be to contact Rob and let him know the situation. I assume that Rob tuned the truck before you installed that turbo?
  1. Garrett 4094 VVT/Boost tuning?
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 31st, 2013, 01:55 PM
  2. Tunning help please
    By aaronr in forum Gen III V8 Specific
    Last Post: May 19th, 2010, 05:53 PM
  3. tunning help
    By CPBAIT in forum Gen III V8 Specific
    Last Post: February 11th, 2007, 08:24 PM
  4. Dry tunning help
    By chevpower in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 21st, 2006, 04:36 PM
  5. Help with tunning tool.
    By 2000zrocks in forum General (Petrol, Gas, Ethanol)
    Last Post: April 1st, 2006, 11:14 PM
