Results 1 to 5 of 5
Thread: $31 out of range
    Senior Member pdasterly's Avatar
    Oct 2007
    Default $31 out of range
    trying to update vin in e38 pcm, getting error message $31
    1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
    1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
    1981 El Camino, 5.3 LSX carb, msd 6010
    2011 2SS
    Oct 2007
    Error report generated by EFILive at 16:39:05 on Oct 14, 2013
    Error code: ERR_RESPONSE/5
    Response $31: "Request Out of Range".
    EFILive Version: 7.5.7 (Build 242)
    Platform: Windows NT
    Version: 6.1 (build 7601)
    Processor type: Pentium 1862MHz
    Directories
    Temporary Cache: C:\Users\Elitebook\Documents\EFILive\V7.5\Temporar y cache
    Logged Data: C:\Users\Elitebook\Documents\EFILive\V7.5\Logged data
    Customers: C:\Users\Elitebook\Documents\EFILive\V7.5\Customer s
    Configuration: C:\Program Files (x86)\EFILive\V7.5\Configuration
    Exported Data: C:\Users\Elitebook\Documents\EFILive\V7.5\Exported data
    Images: C:\Users\Elitebook\Documents\EFILive\V7.5\Images
    Sounds: C:\Users\Elitebook\Documents\EFILive\V7.5\Sounds
    Maps: C:\Users\Elitebook\Documents\EFILive\V7.5\Maps
    Pids: C:\Users\Elitebook\Documents\EFILive\V7.5\PIDs
    Virtual Dash: C:\Users\Elitebook\Documents\EFILive\V7.5\VDash
    Print Reports: C:\Users\Elitebook\Documents\EFILive\V7.5\Print reports
    Bug Reports: C:\Users\Elitebook\Documents\EFILive\V7.5\Bug reports
    Connected: No
    Com port: 0
    Com setup: EFILive FlashScan V2.5: USB
    Requested baud rate: 115200
    Cable id: 7
    Cable code: FlashScan V2
    Cable desc: EFILive FlashScan V2
    Cable version: 2.7.49
    Cable Firmware date: 20230802
    Cable model: FSV2
    Cable Serial number: 003642841043
    Protocols: 0
    Protocol list:
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    Most recently used VIN: 2G1FJ1EJ5B9xxxxxx (Note: 1)
    PCM information
    Hardware Number: N/A
    Calibration ID: 12639269
    Serial Number: 86K21147XCSN
    Operating System: 12639270
    Engine Operation: 12642188
    Engine Diagnostics: 12642190
    Not used: 12632574
    Not used: 12642190
    Fuel System: 12632570
    System: 12642192
    Speedometer: 12632574
    Operating System BCC: AAR2
    Stream-Slow scan mode: Supported
    Stream-Fast scan mode: Supported
    Maximum dynamic packets: 16
    Detected modules:
    $11="Engine Control Module (ECM)"
    $18="Transmission Control Module (TCM)"
    Selected parameters:
    CALC.E38_VE=1,16
    E38.AFRATIO_DMA=1,5
    E38.APCYL_DMA=1,4
    E38.SCALEDCORVE_DMA=1,3
    GM.AFM=1,14
    GM.EXPHAB1=1,4462
    GM.IMTVSTATE2=1,4560
    GM.INPHAB1=1,4580
    GM.KR=1,12
    GM.MAFFREQ2=1,4601
    SAE.ECT=1,9
    SAE.IAT=1,10
    SAE.MAP=1,2
    SAE.RPM=1,1
    SAE.SPARKADV=1,7
    SAE.TP=1,8
    SAE.VSS=1,6
    Most recent communication with vehicle:
    16:37:18.393 Send: $01,$01,$1D,$00,$1F
    16:37:18.405 Recv: $01,$01,$1D,$00,$1F
    16:37:18.507 Send: $01,$01,$1D,$00,$1F
    16:37:18.513 Recv: $01,$01,$1D,$00,$1F
    16:37:19.938 Send: $01,$01,$1D,$00,$1F
    16:37:19.947 Recv: $01,$01,$1D,$00,$1F
    16:37:20.049 Send: $01,$01,$1D,$00,$1F
    16:37:20.055 Recv: $01,$01,$1D,$00,$1F
    16:37:21.587 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:21.596 Recv: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:21.596 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:21.604 Recv: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:23.025 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:23.036 Recv: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:23.036 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:23.052 Recv: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:24.515 Send: $01,$01,$1D,$00,$1F
    16:37:25.117 Send: $01,$01,$1D,$00,$1F
    16:37:25.974 Send: $01,$01,$1D,$00,$1F
    16:37:26.576 Send: $01,$01,$1D,$00,$1F
    16:37:27.555 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:28.415 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:47.815 Send: $01,$01,$1D,$00,$1F
    16:37:47.827 Recv: $01,$01,$1D,$00,$1F
    16:37:47.927 Send: $01,$01,$1D,$00,$1F
    16:37:47.935 Recv: $01,$01,$1D,$00,$1F
    16:37:49.358 Send: $01,$01,$1D,$00,$1F
    16:37:49.368 Recv: $01,$01,$1D,$00,$1F
    16:37:49.469 Send: $01,$01,$1D,$00,$1F
    16:37:49.477 Recv: $01,$01,$1D,$00,$1F
    16:37:50.979 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:50.985 Recv: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:50.986 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:51.001 Recv: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:52.432 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:52.443 Recv: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:52.443 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:52.459 Recv: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:53.887 Send: $01,$01,$1D,$00,$1F
    16:37:54.489 Send: $01,$01,$1D,$00,$1F
    16:37:55.343 Send: $01,$01,$1D,$00,$1F
    16:37:55.944 Send: $01,$01,$1D,$00,$1F
    16:37:56.890 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:37:57.750 Send: $01,$68,$6A,$F1,$01,$00,$00,$00,$00,$00,$00,$05,$8 0,$00,$04
    16:38:35.186 Send: $01,$54,$04,$86,$00,$00,$00,$00,$00,$00,$01,$00,$0 0,$90,$89
    16:38:35.404 Recv: $01,$52,$04,$86,$00,$00,$C9,$00,$00,$00,$00,$00,$E D,$50
    16:38:35.404 Send: $01,$54,$01,$82,$00,$00,$00,$00,$00,$00,$00,$00,$C 0,$91
    16:38:35.421 Recv: $01,$52,$01,$82,$00,$00,$00,$00,$00,$00,$05,$00,$4 6,$53,$56,$32,$00,$97,$B4
    16:38:35.421 Send: $01,$54,$05,$82,$00,$00,$00,$00,$00,$00,$04,$00,$F 2,$00,$00,$00,$5B,$15
    16:38:35.438 Recv: $01,$52,$05,$82,$00,$00,$00,$00,$00,$00,$04,$00,$0 1,$02,$07,$31,$8C,$77
    16:38:35.543 Send: $01,$54,$84,$86,$00,$00,$00,$00,$00,$00,$01,$00,$0 1,$F8,$8B
    16:38:35.558 Recv: $01,$52,$84,$86,$00,$00,$01,$00,$00,$00,$00,$00,$F A,$F0
    16:38:35.592 Send: $01,$54,$01,$86,$00,$00,$00,$00,$00,$00,$01,$00,$0 2,$00,$84
    16:38:35.659 Recv: $01,$52,$01,$86,$00,$00,$33,$00,$00,$00,$01,$00,$0 2,$0B,$8F
    16:38:35.758 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$08,$00,$0 C,$6C,$11,$F1,$27,$02,$00,$00,$EF,$AD
    16:38:35.781 Recv: $01,$52,$82,$86,$00,$00,$06,$00,$00,$00,$06,$00,$6 C,$F1,$11,$7F,$27,$22,$79,$B8
    16:38:35.813 Send: $01,$54,$00,$86,$00,$00,$00,$00,$00,$00,$00,$00,$A 3,$94
    16:38:35.829 Recv: $01,$52,$00,$86,$00,$00,$00,$00,$00,$00,$01,$00,$0 2,$0C,$70
    16:38:35.862 Send: $01,$54,$04,$86,$00,$00,$00,$00,$00,$00,$01,$00,$0 0,$90,$89
    16:38:36.081 Recv: $01,$52,$04,$86,$00,$00,$C8,$00,$00,$00,$00,$00,$E C,$81
    16:38:36.224 Send: $01,$54,$01,$82,$00,$00,$00,$00,$00,$00,$00,$00,$C 0,$91
    16:38:36.241 Recv: $01,$52,$01,$82,$00,$00,$00,$00,$00,$00,$05,$00,$4 6,$53,$56,$32,$00,$97,$B4
    16:38:36.295 Send: $01,$54,$05,$82,$00,$00,$00,$00,$00,$00,$04,$00,$F 2,$00,$00,$00,$5B,$15
    16:38:36.312 Recv: $01,$52,$05,$82,$00,$00,$00,$00,$00,$00,$04,$00,$0 1,$02,$07,$31,$8C,$77
    16:38:36.344 Send: $01,$54,$06,$82,$00,$00,$00,$00,$00,$00,$00,$00,$7 1,$4B
    16:38:36.360 Recv: $01,$52,$06,$82,$00,$00,$00,$00,$00,$00,$03,$00,$1 7,$08,$02,$12,$E8
    16:38:36.390 Send: $01,$54,$23,$83,$00,$00,$00,$00,$00,$00,$00,$00,$6 D,$A1
    16:38:36.405 Recv: $01,$52,$23,$83,$00,$00,$01,$00,$00,$00,$0D,$00,$3 0,$30,$33,$36,$34,$32,$38,$34,$31,$30,$34,$33,$00, $B8,$FC
    16:38:36.433 Send: $01,$54,$24,$83,$00,$00,$00,$00,$00,$00,$00,$00,$D C,$7B
    16:38:36.450 Recv: $01,$52,$24,$83,$00,$00,$01,$00,$00,$00,$0D,$00,$3 0,$30,$33,$36,$34,$32,$38,$34,$31,$30,$34,$33,$00, $DE,$EA
    16:38:36.479 Send: $01,$54,$26,$83,$00,$00,$00,$00,$00,$00,$00,$00,$7 D,$B1
    16:38:36.497 Recv: $01,$52,$26,$83,$00,$00,$04,$00,$00,$00,$0E,$00,$1 F,$00,$00,$00,$03,$00,$00,$00,$03,$00,$0B,$00,$21, $00,$BE,$2D
    16:38:36.498 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$2A,$00,$92,$CF
    16:38:36.517 Recv: $01,$52,$82,$86,$00,$00,$04,$00,$00,$00,$0C,$00,$6 C,$F1,$11,$6A,$00,$00,$00,$00,$00,$00,$00,$00,$B3, $6C
    16:38:36.517 Send: $01,$54,$04,$86,$00,$00,$00,$00,$00,$00,$01,$00,$0 0,$90,$89
    16:38:36.736 Recv: $01,$52,$04,$86,$00,$00,$C9,$00,$00,$00,$00,$00,$E D,$50
    16:38:36.808 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$01,$5D,$6F
    16:38:36.843 Recv: $01,$52,$82,$86,$00,$00,$11,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$01,$00,$32,$47,$31,$46,$4A,$DB,$AE
    16:38:36.843 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$02,$1D,$6E
    16:38:36.882 Recv: $01,$52,$82,$86,$00,$00,$16,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$02,$31,$45,$4A,$35,$42,$39,$AA,$FD
    16:38:36.882 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$03,$DC,$AE
    16:38:36.918 Recv: $01,$52,$82,$86,$00,$00,$15,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$03,$32,$30,$34,$39,$32,$34,$FB,$1B
    16:38:37.168 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0A,$1C,$A8
    16:38:37.187 Recv: $01,$52,$82,$86,$00,$00,$02,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0A,$00,$C0,$DC,$26,$E8,$A5
    16:38:41.100 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$01,$5D,$6F
    16:38:41.136 Recv: $01,$52,$82,$86,$00,$00,$15,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$01,$00,$32,$47,$31,$46,$4A,$99,$6F
    16:38:41.136 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$02,$1D,$6E
    16:38:41.167 Recv: $01,$52,$82,$86,$00,$00,$10,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$02,$31,$45,$4A,$35,$42,$39,$49,$5C
    16:38:41.167 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$03,$DC,$AE
    16:38:41.205 Recv: $01,$52,$82,$86,$00,$00,$15,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$03,$32,$30,$34,$39,$32,$34,$FB,$1B
    16:38:41.489 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0A,$1C,$A8
    16:38:41.510 Recv: $01,$52,$82,$86,$00,$00,$05,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0A,$00,$C0,$DC,$26,$AF,$A7
    16:38:53.882 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$01,$5D,$6F
    16:38:53.917 Recv: $01,$52,$82,$86,$00,$00,$13,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$01,$00,$32,$47,$31,$46,$4A,$7A,$CE
    16:38:53.918 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$02,$1D,$6E
    16:38:53.955 Recv: $01,$52,$82,$86,$00,$00,$16,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$02,$31,$45,$4A,$35,$42,$39,$AA,$FD
    16:38:53.956 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$03,$DC,$AE
    16:38:53.993 Recv: $01,$52,$82,$86,$00,$00,$14,$00,$00,$00,$0B,$00,$6 C,$F1,$11,$7C,$03,$32,$30,$34,$39,$32,$34,$AA,$8B
    16:39:05.175 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$0C,$00,$0 C,$6C,$11,$F1,$3B,$01,$00,$32,$47,$31,$46,$4A,$5D, $80
    16:39:05.190 Recv: $01,$52,$82,$86,$00,$00,$00,$00,$00,$00,$05,$00,$6 C,$F1,$11,$7B,$01,$2D,$2A
    16:39:05.190 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$0C,$00,$0 C,$6C,$11,$F1,$3B,$02,$31,$45,$4A,$39,$42,$39,$5E, $E1
    16:39:05.206 Recv: $01,$52,$82,$86,$00,$00,$00,$00,$00,$00,$05,$00,$6 C,$F1,$11,$7B,$02,$6D,$2B
    16:39:05.206 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$0C,$00,$0 C,$6C,$11,$F1,$3B,$03,$32,$30,$34,$39,$32,$36,$BE, $35
    16:39:05.262 Recv: $01,$52,$82,$86,$00,$00,$27,$00,$00,$00,$07,$00,$6 C,$F1,$11,$7F,$3B,$03,$31,$11,$D1
    16:39:05.851 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$08,$9D,$69
    16:39:05.872 Recv: $01,$52,$82,$86,$00,$00,$06,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$08,$00,$C0,$DC,$25,$D5,$67
    16:39:05.908 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$05,$5C,$AC
    16:39:05.942 Recv: $01,$52,$82,$86,$00,$00,$12,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$05,$38,$36,$4B,$32,$2F,$C5
    16:39:05.942 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$06,$1C,$AD
    16:39:05.982 Recv: $01,$52,$82,$86,$00,$00,$18,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$06,$31,$31,$34,$37,$B3,$AC
    16:39:05.983 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$07,$DD,$6D
    16:39:06.017 Recv: $01,$52,$82,$86,$00,$00,$11,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$07,$58,$43,$53,$4E,$11,$3F
    16:39:06.142 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0A,$1C,$A8
    16:39:06.167 Recv: $01,$52,$82,$86,$00,$00,$07,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0A,$00,$C0,$DC,$26,$2D,$A6
    16:39:06.179 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0F,$DC,$AB
    16:39:06.204 Recv: $01,$52,$82,$86,$00,$00,$09,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0F,$00,$C0,$E7,$8C,$FC,$ED
    16:39:06.211 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0E,$1D,$6B
    16:39:06.235 Recv: $01,$52,$82,$86,$00,$00,$08,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0E,$00,$C0,$E7,$8E,$81,$EC
    16:39:06.242 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0D,$5D,$6A
    16:39:06.267 Recv: $01,$52,$82,$86,$00,$00,$08,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0D,$00,$C0,$C1,$FE,$DE,$68
    16:39:06.274 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0E,$1D,$6B
    16:39:06.297 Recv: $01,$52,$82,$86,$00,$00,$08,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0E,$00,$C0,$E7,$8E,$81,$EC
    16:39:06.304 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0C,$9C,$AA
    16:39:06.329 Recv: $01,$52,$82,$86,$00,$00,$09,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0C,$00,$C0,$C1,$FA,$23,$6B
    16:39:06.336 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0B,$DD,$68
    16:39:06.360 Recv: $01,$52,$82,$86,$00,$00,$08,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0B,$00,$C0,$E7,$90,$CD,$E4
    16:39:06.367 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$0D,$5D,$6A
    16:39:06.392 Recv: $01,$52,$82,$86,$00,$00,$07,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$0D,$00,$C0,$C1,$FE,$91,$6C
    16:39:06.399 Send: $01,$54,$82,$86,$00,$00,$00,$00,$00,$00,$06,$00,$0 C,$6C,$11,$F1,$3C,$14,$9C,$A0
    16:39:06.436 Recv: $01,$52,$82,$86,$00,$00,$14,$00,$00,$00,$09,$00,$6 C,$F1,$11,$7C,$14,$41,$41,$52,$32,$F7,$12
    Report ID: 731086 (Note: 2)
    Notes:
    (1) The VIN sequence number is not required for this report and for your privacy it is NOT included in this report.
    (2)The report ID is a checksum of the report text and is used to verify the integrity of the report.
    2011 2SS
    Did you get that from trying to change the VIN using the scantool or the tunetool...?
    Oct 2007
    Same error on both
    2011 2SS
    Can I ask you to please go here http://support.efilive.com (log in with your forum username/password) and click Ask a Question (see upper left)...
    place "$31 out of range" in the subject;
    fill in as many fields as you can;
    upload the error report (or paste the contents of post #2 into the big box).
    This will help to keep track of this problem and any related problems.
  1. Out of range
    By w/t1500 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 7th, 2011, 12:26 PM
  2. LTFT - range vs + range lean rich question
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 14th, 2009, 06:18 AM
  3. A0011 out of range...
    By brokenfly in forum Custom Operating Systems
    Last Post: October 16th, 2007, 08:35 AM
