Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 159
Thread: Update:Oct 16, 2013
    Default Update:Oct 16, 2013
    EFILive encourages customers to use this public update in their production environments.
    Download here:
    The latest stable release is available here: http://www.efilive.com/downloads.htm
    Additional updates are listed here: http://www.efilive.com/latest/cat/do...e-nov-07-2013/
    Updates:
    V7
    • E92 Preliminary calibrations release.
    • CSP5 V1.01 public release.
    • Cleaned up the DTC editor for late model Duramax controllers.
    V8
    • Fixed some minor issues with number and date formats when using a non-US locale.
    • Added warning prior to editing calculated PIDs that explains the required floating point numeric format when using a non-US locale.
    • Added dashboard/gauge editor (currently available to authorized beta testers only).
    • Updated default dashboard gauges.
    • Added Open/Save options for loading/saving charts and gauges independently of the entire dashboard.
    IMPORTANT
    This release creates (i.e. saves) *.ctz and *.coz tune files that have an updated format that cannot be opened with previous versions of EFILive V7.5 nor EFILive V8. Attempts to open a new file using old software will result in error $0525 "Tune file is not compatible with firmware".
    Note: existing *.ctz and *.coz files can be opened by this and newer versions of the EFILive software.
    Firmware
    • Added support for E20 Custom PIDs.
    • Updated switching support for CSP5.
    Known Issues:
    Please post issues, questions, clarifications (large or small) in this thread.
    As issues are reported and confirmed they will be re-posted as "Known Issues" below.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 244
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 236
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.06 (Aug 02, 2013
    To view the installed version, Select F7: Licenses (in the V8 Scan and Tune software).
    Firmware: V2.07.51 (Oct 11
    , 2013)
    Aug 2011
    Thanks Blacky downloading now.
    Tuning by Zack StarLite diesel
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    Paul,
    Can .coz and .ctz files be created with this version and sent for BBX flash (autocal use) on older platforms, or must customers update their hardware to allow flashing?
    Thanks,
    Nick
    Quote Originally Posted by vortecfcar View Post
    Paul,
    Can .coz and .ctz files be created with this version and sent for BBX flash on older platforms, or must customers update their hardware to allow flashing?
    Thanks,
    Nick
    The old firmware and/or old software will not be able to read the new file format.
    The end users must update their software and firmware to be able to open, and/or flash *.ctz and *.coz files that you create using this latest version.
    Downloading now, as long as I can open old tunes with this Ill be fine. What changed in the file structure, if you can say publicly?
    It was to fix a bug that under some conditions caused the wrong data to be used to generate seed/key locking data which in turn would cause problems when attempting to unlock that same controller later on.
    You can see the entry for it in the Sep 25 release, the one about the E38, E54 and E60 auto-lock fix. The bug fix necessarily "broke" the backward compatibility of the file format. In the Sep 25 release the files were not tagged as incompatible with the older software so the fix was ignored until this release. :(
    And yes opening old tune files with the new software is 100% transparent. You just can't open the newer files with the older software since the older software does not understand the changes made in the newer file's format.
    I remember seeing that comment, thanks for the clarification!
    Lifetime Member wesam's Avatar
    May 2010
    Thanks for the good work
    Any thing for E78 ?
    Is the E92 stream available now ?
    EFILive Tuner
    Nov 2005
    Quote Originally Posted by wesam View Post
    Any thing for E78 ?
    Nothing for E78 however I am pleased to say that has now moved up the development list.
    E92 uses our VIN license system. Stream licenses are an historical legacy retired some years ago.
    Cheers
    Cindy
    Dec 2006
    Installed
    2007 LBZ 2011 LML Silverado Pickups
    2015 GMC Denali 3500 Dually Diesel Pickup
    2007 Dodge 6.7 Pickup
  1. Update: May 25, 2013
    Last Post: June 11th, 2013, 05:28 PM
  2. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  3. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
