Page 11 of 16 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 159
Thread: Update:Oct 16, 2013
  1. #101
    Nov 2012
    just updated all of them prior to loading the tune.
    2007 Ram 2500, AFE Air, AFE Bladerunner Intercooler, ATS Dual CP3's, Steed Speed Exhaust manifold, PMT 5" truboback exhaust, DDP 90hp, II Silver 66, 12 valve balanced rods, ARP studs, Hamiliton Cam and 110# springs, CFM Intake, Crazy Carls Intake plume, MRBP intercooler tubes, GOREND multi-disc torque converter and valve body, billet shafts and more.....
  2. #102
    Nov 2012
    Wow just relooked at them and I have
    V8.2.2.234
    V7.5.7 build 242
    Boot Block ver. 2.07.06
    firmware 2.07.49
    All of which I just downloaded and installed this morning from the EFI down load website.
  3. #103
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Thats not the most current software release. Thats the most current public release. Download software from the links at the beginning of this thread.
  4. #104
    Nov 2012
    Thanks will download and try again.
  5. #105
    Nov 2012
    I do not see the .51 firmware update
  6. #106
    Nov 2012
    Nevermind, got it....
  7. #107
    You will have to start your CSP5 tune conversion again using the version you just downloaded.
  8. #108
    Jun 2013
    Well if you guys can add the speed limiter fields my OS is 12658729. I would really appreciate this before the official release
  9. #109
    Sep 2013
    After you flash a ECM with V8 how do you edit the program again since V7 will not open a V8 tune.
  10. #110
    Quote Originally Posted by camaro68 View Post
    Open the file in V7.5, either open the V7.5 tune tool and File->Open then select the tune or right click the tune file ->Open With and select the V7.5 tune tool.
  1. Update: May 25, 2013
    Last Post: June 11th, 2013, 05:28 PM
  2. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  3. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
