Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 159
Thread: Update:Oct 16, 2013
  1. #121
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    updatde. i did a system restore. it helped me open v8 some but i still am now getting this error Click image for larger version.
ID:	16057 im really thinking its laptop. somehow HAPI is not doing what its supposed to be doing. im reinstalling software now.
  2. #122
    Jun 2011
    Update. All seems to be working well. Not sure what was going on. Laptop just needed to be cleaned up.
  3. #123
    Mar 2007
    Quote Originally Posted by comnrailpwr View Post
    What windows OS is that computer running? My tuning laptop is dead to the EFI Live world. As I plug my V1 or V2 into it it dies. Have not figured it out. That same laptop still works with Motec, Holley EFI, and MegaSquirt. It also runs MasterCam and my DNC software flawlessly. I did all the house cleaning I could do. The computer is really working great now with everything but EFI. My laptop runs XP. I borrowed a laptop that runs 7 and it runs EFI Live without issue. But that computer does not have a native RS232 port that I need. So I need to order a refurbished laptop. Wish I could just get my old laptop to run EFI Live again!
  4. #124
    Mar 2009
    Quote Originally Posted by JOHNBOY View Post
    You can buy an adapter cable to hook that port up to a USB as I had to buy one for my GPS to my new PC.
  5. #125
    Quote Originally Posted by THEFERMANATOR View Post
    I had to buy one too so I can plug my LC1 into my laptop. Wish Innovate would upgrade it to the 20th century (no typo there) and make it USB. Or heck, build the serial converter INTO the unit so it's a USB cable.
  6. #126
    Aug 2013
    Did you try uninstalling the driver?
  7. #127
    Mar 2007
    Not an option. To much EMI at work. I tryed several years ago. Still have them. Every time the files got corrupted. When your dealing with a machine program that has several million lines not worth the risk. Learned that the hard way. A true serial port is the only way to go for what I need.
  8. #128
    Mar 2007
    Quote Originally Posted by statesman View Post
    Yes multiple times. Tried every driver option included with EFI Live per the sticky and at the advice of the tech support. Still no dice. I uninstalled everything. Reinstalled clean. Still no luck. Did a system restore to three months ago and did a clean install. Still no luck. Not sure what else I can do. Everything else works great on that computer but EFI Live.
  9. #129
    Jun 2011
    Been a while since I read all your posts. Does it do this while charging the laptop too? Did you try an external USB port?
  10. #130
    Aug 2013
    Try uninstalling the driver, then uninstall the V7.5 and V8 programs. Go into windows explorer and navigate to Program Files>EFILive. Delete the EFILive folder. Then reboot the machine and reinstall the V7.5 and V8 software but don't install any driver. Plug the flashscan in and see if you get the blue screen or not. If you don't get the blue screen and you get windows detects new hardware, then use the windows wizard to install the driver.
  1. Update: May 25, 2013
    Last Post: June 11th, 2013, 05:28 PM
  2. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  3. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
