If you have a newer laptop, it configures the USB ports for USB3/xHCI...
go into the system BIOS and disable xHCI and/or set USB to USB2.
Please-Read-Windows-8-Users-USB3/xHCI
I'm posting this at the suggestion of joecar. my new v2 will not read out my ls1b controller (2001 corvette a4). my software/firmware is as follows
v7.5.7 build 244
v8.2.2 build 236
boot block 2.07.06
firmware 2.07.51
when I try to read with v7 it says the boot loader is rejected and can't unlock
when I try to read with v8 it says error $0537 controller locked with a custom key
the controller isn't locked as it has been read with hpt less than a week ago. any help is greatly appreciated. I miss my v1 :(
Okay, with no driver installed we know that the driver can't be the problem.
Try plugging the V2 into your car. You won't need to turn the ignition key on, the V2 will draw power from the car with the key off. Now with the V2 powered by the car, plug it into your laptop... see if the laptop blue screens. We're testing to see if the problem goes away when we don't need the USB port to supply any power to the V2.
EDIT: Okay, I just read back and in post #90 you already tried this.
All I can think of is that you have some corrupt file in windows. It's not an XP compatiblity issue as I'm running XP with no problems. You might have to back-up all your files and do a clean install of XP if you want to continue using that laptop.
I removed the drivers and EFI Live files again. Shut down and restarted. Plugged in the V2 without any EFI Live software in the computer. Still crashes. Something is windows is corrupt from the sounds of it. Not sure I want to whip it clean and start again. I need to do some reading on that. Thanks for your help!
Do you mean just reading it with v2 ( no laptop )? If so I can try it later this afternoon and report back
