Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: lmm p0101??
  1. #21
    Jan 2012
    mine has a brand new sensor in it but no change so I changed the limp tables in it for now. it still says reduced power but doesn't actually go into reduce power. took a little to find all the tables but it runs fine but I want to get this issues resolved and put the reduced power ability tune back on the truck.
  2. #22
    Lifetime Member Boost's Avatar
    Dec 2006
    Quote Originally Posted by chevyman2 View Post
    I can do that any thing that can help with this will be a life saver!!
    Try the one I just sent. If it does not work I would try a different OS and / or take away the rumble idle.
    8.7 @ 84 (1/8 mile) bolt-ons
  3. #23
    Jan 2012
    at this point it's working time will tell. I didn't even think about changing that stuff thanks!
  4. #24
    Dec 2006
    Thumbs up
    My pleasure!
  5. #25
    Nov 2015
    boost.. my brother is having problems with his maf on his 08 duramax all he has done to it is dpf delete and egr delete.. I used my efi live to disable the dpf and egr in the computer but is still having reduced power and throwing maf code
  6. #26
    Mar 2009
    Sounds like you overlooked a limiter or a temp enabler. You can't just shut the codes off as this won't always work. You can stop the codes that way, but the ECM will still go to enable them. And just setting them to disable doesn't always work either.
  1. LMM dpf delete P0101 any help? (Canada)
    By bob_22r in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 2nd, 2013, 07:05 AM
  2. maf p0101
    By harleyd33 in forum Duramax LB7
    Last Post: April 5th, 2011, 03:23 PM
  3. Help P0106 & P0101
    By Moonder in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2009, 12:32 AM
  4. Could some one help w/ a P0101
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 30th, 2009, 10:02 AM
  5. Mcrat 20 20 and p0101 p0299
    By Madspeed in forum Duramax LLY
    Last Post: March 25th, 2007, 03:32 AM
