Results 11 to 20 of 23
Thread: 2012 Cruze E78 Rev Limiter Question
    Oct 2009
    Default 2012 cruze rev limit issue base cal
    Here is the file
    Nov 2007
    What error codes do you have when the engine is running? I suspect it is lack of VSS signal
    I'll modify your tune and repost.
    But as others have said, it is because it is missing (a) comms with the TCM for an auto, or (b) missing the speed sensor signal for a manual.
    Oct 2009
    No code pressent
    Try this tune
    Oct 2009
    Thanks i will load it in and report back thank you
    Oct 2009
    Sorry , i can note load this file ; it comes back as can note use this version calibration with this software. I am using a v-2 flash scan and all my software and firm ware are up to current date, i believe. What am i missing.
    Ah, sorry, I am running the version posted here:
    http://forum.efilive.com/showthread....te-Oct-16-2013
    If you update to that you will be able to open the file I posted (and all your old ones too).
  9. #19
    Oct 2009
    I just wanted to report back the results. The modifications that you made worked just fine. The engine runs up to the appropriate rev limiter and performs very well for a stock tune. Now i can complete the tune work thanks to your fix to my base calibration. I am assuming that you will incorporate this address in future updates. Once again thank you for the superior tuner customer support, my customer is very grateful as well.
    Your loyal customer always,
    steve sbelgio
    eclipse engineering
  10. #20
    Thanks for letting us know Steve, yes of course the table will be added for future updates.
  1. HELP 2012 1.4L turbo Cruze tune
    By bstuder11 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 19th, 2014, 01:05 AM
  2. Speed limiter setting on E78 PCM - Chevrolet Silverado 2500 HD 2011
    By Treurentner in forum E78, E83, E84 PFI ECM's
    Last Post: October 9th, 2012, 01:46 PM
  3. Rev limiter help
    By charcold-bowtie in forum Gen III V8 Specific
    Last Post: May 28th, 2009, 03:51 AM
  4. Rev limiter help
    By Badmire68 in forum Gen III V8 Specific
    Last Post: January 17th, 2008, 10:53 AM
  5. 97 C5 Rev Limiter ?
    By Kool C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2007, 12:28 PM
