Results 1 to 5 of 5
Thread: Adding Fuel Pressure to LS1
    Jun 2009
    Default Adding Fuel Pressure to LS1
    I wired in an old fuel pressure sensor I had laying around to my V2. I can see the voltage the v2 is getting with the ext.ad1 pid, but the calc.fp is not being recognized when I'm connected, and I don't know why. I have attached my calc.pid.txt file. Is there anything else I need to do to get the fuel pressure reading working?
    I'm guessing it has to be something with my configuration in the scan tool since it can see the 0-5volts from the sender, just isn't displaying fuel pressure.
    Try this: delete the definition of units "PSI", and change the two references to "PSI" to "psi".
    Jun 2009
    Like this? Cause this didn't work either. I've tried just about anyway with defining PSI in caps, caps with quotes etc... tried it with out both ways and nothing seems to work and i can't figure out why... I am reading voltage from the external input 1 but it isn't calculating into PSI, and it isn't showing fuel pressure as a valid PID.
    Jun 2009
    figured it out... I had () instead of {} in the formula part. changed that and works like a charm.
    Ha, good catch
  1. Replies: 3
    Last Post: September 20th, 2011, 01:04 PM
  2. can I log fuel pressure with my glowShift fuel pressure gauge?
    By ryans1000 in forum External A/D inputs
    Last Post: August 16th, 2011, 01:35 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Adding Headers and expected Fuel trims
    By Beer99C5 in forum Gen III V8 Specific
    Last Post: April 25th, 2007, 01:35 PM
  5. Adding fuel
    By Lennart in forum General (Diesel)
    Last Post: January 18th, 2006, 03:43 PM
