Results 1 to 1 of 1
Thread: DBW to DBC cable conversion
    Jul 2005
    Default DBW to DBC cable conversion
    I'm doing a DBW to DBC conversion on a '04 LQ4. I've got a 12576106 PCM that has the IAC driver hardware on board.
    Since the stock DBW tune already has the IAC tables populated, is there anything else needed within the tune other
    than changing the System>Vehicle Platform>G1207 for the Electronic Throttle from Yes to No? I would think this is what
    tells the PCM to use the throttle body TPS/IAC and not look for a TAC module. Will I still need to set DBW related codes
    to not reported?
    Thanks for any help y'all can give!
    '03 GMC 1500HD
    '79 Pontiac LeMans-LQ4/4L80E
    '05 CTS-V
  1. Need a little help with a DBW to DBC conversion
    By JUSTASBC in forum Gen III V8 Specific
    Last Post: September 3rd, 2011, 10:19 AM
  2. dbw to cable TB
    By driver456 in forum Conversions / Aftermarket Parts
    Last Post: June 28th, 2011, 01:02 PM
  3. cable to DBW swap?
    By Aloicious in forum Conversions / Aftermarket Parts
    Last Post: April 29th, 2011, 07:47 AM
  4. DBW Issue
    By sparkinak in forum Gen III V8 Specific
    Last Post: August 23rd, 2008, 01:45 PM
  5. ETC to Cable Conversion?
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: November 17th, 2006, 04:58 AM
