Results 1 to 10 of 15
Thread: What am I missing?
    Feb 2005
    Default What am I missing?
    Looking for a little help trouble shooting.
    I was driving the car and had rolled into the throttle 3/4 and someone pulled out in front of me and I let off suddenly and the car died. It will not start now. I have fuel and I get TPS signal but am not seeing injector stats at all. Of course I really have no idea how to test this without the car running. I am running the normal PIDs and hitting the record button and cranking the engine, most of the PIDS have activity except the injectors. Is there a better way to test during engine cranking to see what is working or not?
    Matt
    When cranking...
    a. check for spark (pull wire and using a screwdriver provide a 'gap' and observe spark while cranking);
    b. put your finger on an injector and feel it pulse while cranking;
    if both of the above fail, then you need to check the crank sensor.
    if only one of the above fails, then check that subsystem.
    Also, turn key on, pull cap from end of fuel rail, quickly press in valve and see if fuel sprays out (use a rag to catch it);
    if this fails, then fuel pump/regulator is broken.
    Oct 2005
    Any PCM codes?
    2014 VF SV LS3 Maloo.
    Image of log chart...?
    While cranking, do you log RPM...?
    Feb 2005
    No RPM when cranking. I do have fuel pressure and the pump is working. I have checked the fuses and see no bad ones.
    Feb 2005
    If I add PID GM.CASERL to the list to scan while cranking I get an error and it will not log. This is Crank angle sensor error attempts to learn. I have tried to reset everthing I could removed power from system to see if it was something in the PCM. I am getting no codes set except the generator one from running the battery down cranking it. I have it on a charger now.
    The PCM derives RPM from the crank sensor signal, and uses the crank sensor to time the injectors and plugs.
    Edit: (Also check that ECT makes sense... but you're not getting RPM so ECT doesn't matter just yet).
    Feb 2005
    Well got the car on jack stands I guess I will yank the starter and pull the crank sensor, be my luck it will not be the CPS.
  1. Another missing PID
    By gmh308 in forum Black Box Logging
    Last Post: September 29th, 2009, 12:00 PM
  2. Missing VIN
    By 99STEPSIDE in forum FlashScan V2
    Last Post: February 11th, 2009, 02:30 PM
  3. E38 Missing tables? Or I'm missing something?
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 7th, 2009, 02:28 PM
  4. PID's Missing or am I missing something
    By dperry in forum Duramax LLY
    Last Post: March 1st, 2007, 02:15 PM
