Results 1 to 2 of 2
Thread: AutoVE, What next?
    Jun 2003
    Default AutoVE, What next?
    Ok I went through and did the Open Loop, and Closed Loop. Now confirming the LTFT but I am using one sides SB bung hole ( ha bung hole ( shut up beavis ), sorry could not resist the potty humor ) and just go off the one?
    Do I leave it here? Put everything back enabled? Keep running without the MAF ( preferred, its running and idle better then it ever has )
    If so, do I just tune WOT without the PE and just change the AFR based on the VE table and just richen/lean it out in the needed MAP X RPM regions? If so thats simple enough.
    Just checking since the autove just stops at confirming the LTFT and does not go into detail for WOT and long term use.
    Jun 2005
    AutoVE does everything in your VE table, which is your foundation. Whatever you command as your stoich (i.e. 14.63) will be calculated off of what you put in the VE. So, you should have done WOT in AutoVE (while commanding a safe AFR with the Fueling in Open-loop Table). When you put the open-loop fueling table, closed-loop talbe, DFCO table, LTFT's, etc. back to stock, your car should now know where stoich is and therefore will hit the right AFR commanded in the PE table. Then, all that is left to do is to dial in the MAF if you want to use it. If not, leave it disabled and have fun.
  1. Replies: 32
    Last Post: June 24th, 2010, 06:21 AM
  2. AutoVE help please
    By LS1-450 in forum Gen III V8 Specific
    Last Post: May 6th, 2009, 09:23 AM
  3. doing autoVE
    By nathans1987 in forum Gen III V8 Specific
    Last Post: May 3rd, 2009, 06:20 PM
  4. What do I do after the AutoVE is done?....
    By FreddyG in forum Gen III V8 Specific
    Last Post: September 29th, 2007, 03:52 PM
  5. autove afr
    By 91LS1S10 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 14th, 2006, 07:59 AM
