Hi I am new to all this and was wondering what the fuel balance rates mean? I have new exergy 100 hp injectors and some injectors are 2 away from eachother or sometimes even 0. I would like to know if I have 2 bad injectors or is there a reason the injectors are dumping more or less fuel? This is a completely different question but monitoring trans. temp in efi live, does it read in the valve body or where exactly is it reading the temp at? I have a new sun coast with mag pan, i deleted the stock trans cooler and put in a tru cool that is rated for about 40,000 gvw and just cruising down the highway my temp is at 180-183 and that is on a 74 degree day.
