Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Problems after reflashing
  1. #21
    Dec 2005
    Quote Originally Posted by DocZ28 View Post
    Yesterday I was re-flashing, a PCM, and have a issue with it, after the file was loaded, I can´t start the car, so I check if it was done rigth cuz I´m affraid after what happen with my pcm. And the curious thin was that Efilive softwere said me that PCM was in an unknow state, I did try to reflash and full reflash with no succes. I was worried so I did not save any screen or bugs what I remember is that said something about PCMLocks.ini.
    After I try several times, I get connected with the pcm and do a reflash, after that I have no problems.
    My question is What is the possibility that my divice is failing? I will reinstall the software and test or could be my windows 7 the problem.
    mine was doing it in v8 so i went back to 7.5 ,it would say theres a lock or some thing
    try using 7.5 if your using v8
  2. #22
    Senior Member DocZ28's Avatar
    Mar 2007
    Mine is V1, and using V7.5. I´m will reinstall and check again, What is sure is that I´m not confident when I do a reflash, I did change the two cables, So I´m affraid that the divice could be damaged, but those things are not supposed to fail rigt?
  3. #23
    Can you post the text that appears during flashing...
  4. #24
    What year/model is your car...?
  5. #25
    Mar 2007
    Can´t remember all but here is what I recall
    Auto detect pcm
    PCM Detected
    Seed 7$... something
    Initializing 1 of 4
    Initializing 2 of 4
    Initializing 3 of 4
    Initializing 4 of 4
    Abort
    Flash memory can not be errased
    This happend after I did a reflash. and every time I try was the same.
    After that I try to do full reflash and a recover pcm and always I get the response that PCM was in an unknow state.
    As I saw info in the pcm like vin, os, I give a shot to download the file tune, and that did work, after that I have no more problems, So I do not what happen. Next time I will save the messages.
    My car is 00 Camaro with 02 OS and my pcm is dead, I have to purchase another one. And this last one Is a 02 Transam
  6. #26
    Abort
    That error can happen when the battery voltage is too low or too high. Make sure you have a good quality battery and that is fully charged before you attempt to flash the PCM.
    Reading will still usually work even if the battery voltage is too low/high. Flashing requires the battery voltage to be very close to 12V which is needed to erase the ECM's memory.
  7. #27
    Mar 2007
    Update...
    New PCM flashed and working. I didn´t have any problems since last time.
    I bought a PCM 12200411 and works good, well to be honest I don´t see any difference.
    Thanks for your help
  8. #28
    Update...
    So the previous PCM was bad...?
  9. #29
    Mar 2007
    Gone bad. It is empty
  1. Reflashing PCM from M to A ?
    By Garry in forum Tips and tricks
    Last Post: July 30th, 2010, 06:56 AM
  2. Problems reflashing due to something bad
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: March 30th, 2009, 10:52 PM
  3. Reflashing ecu
    By c55asleep in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 5th, 2009, 11:17 AM
  4. reflashing the e67
    By nycblazer in forum Gen IV V8 Specific
    Last Post: April 17th, 2008, 11:10 AM
  5. Reflashing BCM?
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2004, 08:28 AM
