Thread: Cannot get started sure need input
    Oct 2013
    Default Cannot get started sure need input
    Hi all just bought autocal i am trying to update OS for dsp5 switch it says open efilive scan tool but when i do it says cannot find folder i click ok then it says i am in Demo mode and i need to register it i have done that already and received confirmation but i cannot get out of demo mode it just closes. Any input on what to do? I could not find this info in getting started here
    Senior Member WyoFreeride's Avatar
    Sep 2011
    Quote Originally Posted by sticky View Post
    You probably need to contact the Tuner that you purchased the Autocal from. As far as I know, you can't write your own tunes with an autocal only, the V2 that the autocal is linked to must be plugged in when the file is saved for remote flashing.
    2010 Dodge QCSB 6.7 Auto
    Oct 2013
    Quote Originally Posted by WyoFreeride View Post
    I bought it from creatures of the night thier instructions are to open ifelife tune tool and do a full flash i am not trying to write a program only install it
    Lifetime Member tokymon's Avatar
    Apr 2008
    plug youre auto cal in before open program on computer, that should get you out of demo mode
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
    Oct 2013
    Quote Originally Posted by tokymon View Post
    I think i did that but will be 100% tonight will redo thanx i am waiting for creatures of the night to contact me also hopefully i will hear from them in 24 hrs?
    You need to wait for your tuner to contact you. I have no idea what their SLA/common response time is and neither does EFILive as it is out of our control.
    You cannot create tunes yourself, you can ONLY flash tunes your tuner creates and sends to you. Even other tuners cannot supply you tunes, your AutoCal will not flash tunes created by anything other than your tuners FlashScan V2.
  1. How do I get started?
    By tdmkr496 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 17th, 2013, 02:02 AM
  2. Just getting started
    By mjriggs in forum Tutorials
    Last Post: August 25th, 2010, 04:01 PM
  3. Just getting started need help
    By 99ss in forum Gen III V8 Specific
    Last Post: September 7th, 2007, 03:30 AM
  4. Getting Started
    By DMaxME in forum Duramax LLY
    Last Post: April 15th, 2007, 06:45 AM
  5. How to get started ??
    By Lennart in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2007, 06:36 AM
