Results 1 to 10 of 15
Thread: Attempting to get tune correct so no gas pedal is needed on cold starts...
    Jan 2013
    Question Attempting to get tune correct so no gas pedal is needed on cold starts...
    Basically have tried adding air with table B4343, but I can't seem to get my cammed lq9 to start and stay running without giving it gas on cold starts.
    It only starts without pedal effort when it is up to operating condition.
    I am posting a log of a cold start attempt without touching the gas I did this morning. It starts but dies a second later. Then have the full warm up logged in Drive. Also attached tune file
    +DFCO1300_1200.ctz
    LS1B_0163.efi
    Any help?
    Jan 2013
    No help?
    Read this thread and follow the instructions, should get you pretty close.
    http://forum.efilive.com/showthread....ips-amp-Tricks
    Jan 2013
    Already have all that taken care of.
    It idles fine, I am trying to get cold start idle to occur without giving gas. Right now I have to give a little gas for a few seconds before letting off and idling fine.
    Trying to get to where I just start the truck and it goes straight to idling fine.
    Look at B4343 and B4304 and the other parameters associated with that group of parameters.
    Lifetime Member macca_779's Avatar
    Jan 2007
    Add air to start up friction in the areas it's having trouble
    Jan 2013
    I have already messed with b4343
    The values below are what are in the tune file I have attached to my first post.
    Do I just keep adding air until the problem goes away? Because its already higher than any idle tutorial I have seen so far.
    My current Startup Friction Air flow correction
    -40 F 15.500000
    15.000000
    14.500000
    14.000000
    13.500000
    13.000000
    12.500000
    12.000000
    11.500000
    11.000000
    9.500000
    9.000000
    8.500000
    8.000000
    8.000000
    284 F 8.000000
    Jan 2013
    Anyone have any suggestions after looking at my tune file and the log on what to do?
    I'm still looking and thinking...
    Jan 2013
    Thank you, appreciate it
    Quote Originally Posted by slows10 View Post
    Cam specs?? Idles at 54-56 kpa Probably not real big I hope. Why are you setting the idle only 725 rpm? Comanded afr does not equal actual afr. How did you tune the ve and maf tables?
    Cam specs are 222/224 .604/.604 on 112 lsa
    Idle rpm is 725 because it can idle at that just fine. Do you mean I should go lower?
    If you mean higher, what is the benefit to a higher idle for cold crank or anything else?
    AFR was determined with LM2 wideband, and Calc.VET was used for VE and MAF data. And i'm sure you know, MAF data doesn't have an effect on cold start, being that it is in open loop.
  1. Loaded tune and truck starts then dies
    By dsltnr in forum Cummins 5.9L
    Last Post: February 10th, 2014, 07:16 PM
  2. Attempting a SD Tune
    By TurboCamaro in forum General (Petrol, Gas, Ethanol)
    Last Post: August 31st, 2010, 08:12 AM
  3. help with gas pedal
    By litreddevil in forum Petrol / Gas
    Last Post: January 11th, 2008, 04:41 AM
  4. Cold Start: Starts and stalls...
    By 808ws6 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2007, 08:34 PM
