Results 1 to 3 of 3
Thread: False Knock?
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default False Knock?
    I am chasing some knock at around my stall speed that doesnt want to go away. I wonder if it a vibration through the car from the big changes in force when the car hit stall speed on kickdown etc. The knock doesnt seem to impact on the afrs??
    Here are some pics
    I have not that much timing in the trigger areas - yet up to 28 deg at high rpm without issue.
ID:	606   Click image for larger version.
    Oct 2005
    Hmm, looks like just single instances rather than a consistent rattle. There was discussion on this before and I think Delco suggested that if you arnt seeing a saw tooth effect from sustained knock then it might just be a one off occurrance.
    From my investigations if you arnt hearing any knock, you are getting the odd spike here and there and none under sustained load, then forget about it.
    Id be interested to see what others have to say these days on the topic.
    2014 VF SV LS3 Maloo.
    If you are suspect of detonation, you could just make the timing like 15 degrees in that area and see if it still shows KR.
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  1. Possible False Knock
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2009, 01:32 AM
  2. What to do when you get false knock???
    Last Post: May 19th, 2008, 02:30 PM
  3. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2008, 04:18 AM
  4. False Knock?
    By sean3393 in forum Vortec V6/V8 Specific
    Last Post: February 5th, 2008, 11:36 AM
  5. Knock after COS #3 install, but never had knock before
    By CRU SS N in forum Custom Operating Systems
    Last Post: June 15th, 2007, 10:07 PM
