Results 1 to 7 of 7
Thread: Map sensor question / 37 psi @ sea level?
    Dec 2006
    Default Map sensor question / 37 psi @ sea level?
    I've been wondering about this for a while but have not had the chance to check the part #s on the sensors yet. I am assuming that all 3 vehicles I am working on have a GM 3 bar map sensor as the all run more than 15 psi boost from the factory (although they could possibly use a 2 bar "boost sensor" just for pressure?)
    Perhaps I am logging / looking at the wrong PID - or doing something even more foolish. The E39A, E78, and E35B all seem to max out at 37.0 psi "Intake Manifold Absolute Pressure". I have been looking at this PID and subtracting about 14.6 to estimate boost pressure because I am at sea level.
    I find it hard to believe that all 3 vehicles are topping out at around 22 psi, regardless of the tune I am running. At first I really thought the map sensor was maxing out, but then I realized if they were using a 2 bar it would max out at less than factory boost?
    It is also possible that I am not understanding something about basic map sensor operation...
    8.7 @ 84 (1/8 mile) bolt-ons
    Feb 2012
    Aren't the factory boost systems 2.5bar? (2.5 x 14.6 = 36.5)
    What is 22psi in kPa? If it is 255 then that is the upper limit of the ECM.
    Nov 2007
    37psi is the limit of the ECM. 255kPa = 36.98 psi
    Sorry, I meant to say 37.0 psi (as Roland posted), not 22.
    Dec 2006
    Quote Originally Posted by darcy View Post
    If that was the case it would suggest that at sea level I am running 2.5 bar boost (?)
    I feel extra dumb today but the only way to learn this correctly is to ask questions and understand the answers. Let me look this up in GM Service information to see if there is a Descripton and Operation...
    Dec 2006
    Quote Originally Posted by Boost View Post
    Ok so on the LHU engine (E39A) there is a "Intake Air Pressure and Temperature Sensor" that I suppose only has to read boost and a MAP sensor that may only need to read vacuum to low boost (?)
Name:	Da Summer boost system.gif
    #16 is the "boost sensor" & #18 is the map sensor
  1. re-calibrating the fuel level sensor {F0101}
    By LB72004 in forum General (Diesel)
    Last Post: October 5th, 2016, 05:18 AM
  2. Question about 2-bar MAP sensor
    By SSpdDmon in forum Gen III V8 Specific
    Last Post: September 21st, 2009, 05:42 AM
  3. COS5 With A 2 Bar Map Sensor Question
    By ForcefeedWS6 in forum Custom Operating Systems
    Last Post: August 23rd, 2007, 09:39 AM
  4. 2Bar MAP Sensor with MAF Question
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2005, 09:26 AM
  5. I am buying Flashscan, I run 20 psi...... What map sensor???
    Last Post: June 3rd, 2005, 10:17 PM
