Results 1 to 4 of 4
Thread: Holding REVs when changing Gear
    Dec 2011
    Default Holding REVs when changing Gear
    Hi
    I have fitted a 4.3l V6 from a 2005 Chevy astro into a 1945 army jeep. the astro was an auto but I have fitted a manual gearbox.
    I have been able to work out most things from searching the forum and have the jeep running fairly good.
    The only problem I have not been able to fix is, if revved over 2500 rpm when I depress the clutch to change gears the revs hang.
    I have played with the throttle cracker in gear and it is better but I am not sure I am on the right track.
    I also enabled and set up DFCO but this didn't change the hanging.
    so couple of questions - am I on the right track playing with the TC
    Do I need to add an input into PCM to tell it I am in gear
    Or do I need to add a clutch input.
    I have attached my tune file
    Thanks Darren
    Jul 2005
    Have you tried a 4.3 manual transmission calibration? There shold be plenty of 4.3/manual transmission calibrations around.
    Do you have a VSS(Vehicle Speed Sensor) input to the PCM? That input is what tells the "brain" how fast the vehicle is moving and what it should tell teh engine to do.
    peace
    Hog
    1997 rcsb stock L31 longblock, Marine Intake with 28# EV6 injectors, L35 2700 stall TC,Hooker LT's 2.007 60ft
    Dec 2011
    Thanks Hog
    Yes I do have vss connected.
    I do have some manual tunes for the 4.3 but when comparing them to the tune I am using I can't see any difference that I thought would make a difference.
    Just because there arent any visible differences doesnt mean there arent differences. There are ALWAYS differences between an auto and manual calibration. Im assuming since it's an 05 engine that it's a 1MB LS1B PCM, shouldnt be hard to find a 4.3L/manual OS and full flash it like hog suggested.
  1. Holding 4th gear for Dyno
    By Matt68 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 30th, 2011, 03:59 PM
  2. effect of changing stabalization gear ratio
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 2nd, 2010, 11:58 AM
  3. anyone changed the speedo revs/mile on an 09?
    By camcojb in forum Allison 5 & 6 Speed
    Last Post: August 30th, 2009, 12:53 AM
  4. Looking for 2010 Camaro 21" wheel revs/mile
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: August 5th, 2009, 02:20 PM
  5. Changing gear ratio
    By Koncrete in forum General (Petrol, Gas, Ethanol)
    Last Post: June 23rd, 2006, 08:02 AM
