Results 1 to 9 of 9
Thread: Need help loading a tune file.
    Oct 2013
    Default Need help loading a tune file.
    First I am a noob at this tuning stuff and efi live. Questions are when I read a tune file in my 2011 Silverado how to I save it. Second question
    what the difference in downloads. Like loading just the cal and loading operation system and cal. Please help???
    File->Save As and give it a filename, e.g. "2G2FV_0000.ctz".
    Cal Only Flash: flashes just the calibration (tables/parameters). <-- you do this anytime you change the content of parameters/tables.
    Full Flash: flashes everything (OS, calibration, everything else). <-- you only do this if changing the OS.
    Oct 2013
    Thanks I just load a full tune into my truck. If I want to charge rev limiter or cranking ve I could do just the cal flash right?
    Quote Originally Posted by byrdman11 View Post
    Yes, correct, you could have just done a cal flash.
    Please: Do not do full flash when all you need is a cal flash...
    full flash takes longer and has a window of miss-opportunity at the beginning where if things go wrong they can stay wrong.
    Oct 2013
    When should I do a full flash. And what a operation systems???
    You would only do a full flash if you wanted to change the OS in the PCM.
    In tunetool, go View->Show Calibration Window, at the top you will see Operating System id number.
    For example:
    - my 2001 F-car came with OS 12202088,
    - I changed OS to 12212156 (from 2002 F-car),
    - and then I changed OS again to 02020005/COS5 (Custom Operating System 5);
    but in order for me to do those OS changes, I had to first understand whether they were compatible and what I would gain.
    BUT, you should stay with the OS you currently have...
    AND, you should not do a full flash (unless otherwise instructed to do so... i.e. basically never).
    Aug 2013
    For example:
    What did you gain by changing from OS 12202088 to OS 12212156 ?
    Quote Originally Posted by statesman View Post
    I could then run COS5 as needed
    ( and I think GM fixed a transmission issue with 3->4 flare )
    Jan 2009
    I was reading this thread with the difference between cal flash vs full flash. I was also reading another post on here about merging two tune files, (I can try finding it and posting a link to it). But, it was basically using the engine parameters from one tune and taking a manual transmission parameters from another tune to create a custom hybrid tune file. Would that require a full OS flash or still just a cal flash?
    I'm basically going to use the engine parameters from my 2000 Tahoe, and merge a 99+ Fbody 6 speed manual trans files into it. (converting the Tahoe to a T56 manual trans)
    Mike
    1997 Z28 LS7 Engine Swap - Money Pit
    2000 NBS Tahoe Daily Driver
  1. Autocal Tune Loading Issues
    By boaty3 in forum AutoCal
    Last Post: March 20th, 2012, 11:23 PM
  2. loading a tune into flashscan v2
    By latemodel68 in forum FlashScan V2
    Last Post: September 12th, 2010, 04:22 PM
  3. little help loading tune
    By aaronr in forum Black Box Logging
    Last Post: July 4th, 2010, 08:22 AM
  4. 411 swap, loading new file?
    By haulinit in forum General (Petrol, Gas, Ethanol)
    Last Post: April 11th, 2009, 03:18 PM
  5. Latest tune -1 loading
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: March 8th, 2005, 06:38 PM
