Results 1 to 7 of 7
Thread: $06ff error on E38
    Jul 2012
    Default $06ff error on E38
    I'm getting an $06ff error on autocal trying to load base tune in a camaro. autocal pulls tune out fine, I'm assuming it is a checksum problem. Car was originally tuned by someone else with a different program. Can this be fixed or Do I have to have GM reload factory program?
    Calibration Dept
    Jul 2012
    here are the two filesVannoy_tune.tunVannoy_backup.ctz
    Calibration Dept
    Jul 2012
    No ideas
    Calibration Dept
    I know there is one tuner out there that causes this, let me check your files and see.
    Here is the stock tune 'fixed' so you won't get that error.
    Also, do you know what program created the tune initially? I am going to guess and say LS2 Edit?
    Jul 2012
    Yes Im 99% sure it was LS edit. we have run into it before, and had GM flash factory OS, so we could work on it. Thank you for fixing the issue!
    Calibration Dept
    Yes, a TIS flash will fix it too, essentially they are storing CVN correction data where they should not be. There is one of the hand held tuners that does this too (but I don't recall which one).
  1. Autocal Error $06FF
    By Mike@Vengeance in forum AutoCal
    Last Post: July 30th, 2013, 12:49 AM
  2. Replies: 2
    Last Post: July 17th, 2012, 03:27 PM
  3. $0331 Error E38
    Last Post: November 18th, 2011, 09:48 AM
  4. E38 will not reflash License error
    By markemac in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2009, 07:58 PM
