Here is my tune. and calc.pid files. I have B3607 set to 9.7 for e85. My injector duty cycle is staying under 90% and it is running rich, so once VE is dialed in it should be less than 90%.
Also if you could double check my calc_pid file I believe it is using lambda, and that is also what I'm creating the maps with. (I think every time i post logs it confuses everyone. I am logging lambda and AFR but display the AFR on the dashboard, as I am use to reading AFR not lambda or eq.)
BTW to clarify the "BEN" factor is basically the factor the scan tool map is creating to show how far off your VE table is from making it run at the correct afr you are commanding in the tune, is this correct? If so will this ever become "1" as I have ran calc.maft almost every time i drive the car and it is always recommending the slightest changes.
