I was thinking about this more. When i disabled my LTFT it seems like the VE table was dead on and the car was running at commanded afr, where as when LTFT were enabled it would always run a bit rich as once in PE the LTFT value was being added to the VE tables values....
Is it possible to run STFT and leave LTFT disabled? this way the o2 sensors are still working at idle and part throttle. Then once I get into PE it will use the VE table with out the added percent of the LTFT. Seems like it would be much more precise at idle, cruising and at WOT as well with LTFT disabled.
