I am having an issue with the new CSP5 Switching, issue are as follows
1. The last tune you have loaded is suppose to stay active once you shut the vehicle off, or unplug the V2. Mine revert back to tune 5 every time. Anybody know why or have this issue?
2. The PTO enable block is enabled, but can not get it to work, what the secret?
3. I set my idle speed vs coolant D5751 to have the engine rpms come up when I start the vehicle in cold weather, like say 10* 800rpm, -3.9* 1100rpm, -23.3 1200rpm and when I start it in the morning with temps at 40* it does not idle up no matter what I change it to on the low side, but on the high side if I set it to idle 900rpm at 215* it will?
4. Skim Key, no matter what I change in the EFI live tuning I keep getting this DTC?
Can any of you Admins or anybody answer these, or has any one else had these problems?
I have re-installed the Oct 16 2013 updates on 7.5 ver 8 and the firmware.
