Results 1 to 7 of 7
Thread: Is Camaro 2014 V8 still E38?
Hybrid View
    Aug 2010
    Default Is Camaro 2014 V8 still E38?
    Like title says, thank you.
    Nov 2005
    It should be the same.
    Cheers
    Cindy
    Senior Member doubledip's Avatar
    May 2008
    Quote Originally Posted by cindy@efilive View Post
    Cheers
    Cindy
    will depend which engine
    normal ls3 will be but the LSA more than likely will be a E67
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
    Nov 2005
    The original post asks it it's "still using the E38". The supercharged engine never used E38, only E67.
    Cheers
    Cindy
    Aug 2010
    The 2014 L99 / LS3 Camaro runs OS12656198 (E38), while the 2014 Camaro ZL1 runs OS12656245 (E67). The interesting thing about the 2014s is the TCM OS.
    The ZL1 Camaro debuted in 2012, and claimed to have improved the execution of the Tap Shift feature. This was sometimes referred to as "Staged" Tap Shift, but essentially employed a predictive algorithm. This used a completely new TCM OS - and was only available with the ZL1.
    For 2014, this formerly ZL1 only TCM OS is being used by all A6 Camaros (6L80 & 6L90) and by the CTS-V.
    Quote Originally Posted by Taz View Post
    Interesting.
    May 2014
    I am running a 2013 Camaro SS LS3/6L80 retrofitted in my 68 C10 truck. I have a Speartech harness and a ShrifterSix paddle shifter setup. The paddles work great when I'm in M (sport) mode. When I touch on of the paddles it activates the TUTD feature and allows me to paddle shift the transmission. I can even hold the + paddle for 2 seconds and it will take it out of TUTD and and put the tranmission back in sport mode so that the transmission automatically shifts. However, the one feature I haven't been able to get to work is the temporary activation of the paddles in the "D" mode. I know on the 2012+ Camaros/Corvettes, you can press one of the paddle shifters and it will temporarily allow them to work (TUTD) in the D selector position. But, the transmission will eventually go back to shifting the transmission automatically. Any suggestions? Thanks in advance.
  1. Are the 2014 trucks supported yet ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: October 15th, 2013, 04:13 PM
  2. 2013 Camaro E38 - Tuning and warranty
    By 1BadAction in forum E37, E38 & E67 PFI ECM's
    Last Post: March 8th, 2013, 11:13 AM
  3. Manual Trans Rev Limit E38, 2010 Camaro?
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: May 9th, 2012, 10:17 AM
  4. 69 camaro e38 ecm compatibility question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: April 11th, 2012, 11:23 AM
  5. 2010 E38 Camaro 6 speed NO VATS?
    By v8vegaman in forum Petrol / Gas
    Last Post: November 24th, 2010, 04:40 PM
