Results 1 to 10 of 17
Thread: 3bar COS only logging to 255kpa
    Jul 2010
    Default 3bar COS only logging to 255kpa
    Basically when logging it will go to 255 kpa and flat line. Not sure if the tune is still following above that point and just not logging above or if it's a issue with the v2 not reading the map correctly. The map is scaled correctly as well.
    The PCM's range for reporting the MAP pid is upto 255 kPa.
    The COS's Boost VE table ranges upto 285 kPa regardless of what the MAP pid reports.
    But this still leaves the range 255-285 kPa hard to tune.
    Off the top of my head there is another MAP PID that will read beyond the SAE.MAP 255kPa limit.
    Jul 2010
    Can you recall the pid name by chance?
    Lifetime Member picnic_george's Avatar
    Jan 2007
    Is this a limitation of the OS itself or the PCM?
    The pid SAE.MAP ranges 0-255 kPa... I believe it's the OS.
    Like Ross said, there is another MAP pid, but I don't see it...
    Quote Originally Posted by BAD BOB View Post
    No sorry I don't remember.
    Quote Originally Posted by picnic_george View Post
    It is a limitation of the SAE defined PID, not the PCM.
    May 2008
    Any update on this? Need to be able to log to the end of the map sensor.
    May 2008
    Anyone?
    Jan 2014
    Can you log MAP voltage? and scale it yourself with a custom PID?
  1. 3bar COS logging only to 255kpa
    By BAD BOB in forum FlashScan V2 BB Logging
    Last Post: June 28th, 2013, 03:01 AM
  2. reduced engine power after 3bar install
    By 9secVette in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 29th, 2006, 08:39 AM
  3. 3bar custom OS questions
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2006, 03:33 PM
  4. 3bar spark strangeness above 512 g/sec
    Last Post: October 9th, 2005, 10:56 AM
  5. Custom OS 3bar problem (need the experts)
    Last Post: September 12th, 2005, 04:10 AM
