Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 3bar COS only logging to 255kpa
  1. #11
    I think that's going to be your only bet, just because it's a 3 Bar MAP doesnt mean the PCM can see the whole range. There are hardcoded limits (like the 255kPa limit you found) that you cannot get around, the PCM will never be able to see it. If you HAVE to have it, you're going to need to scale everything and get creative on how to display everything. FWIW, I see this being a huge can of worms and would not suggest it, likely way more headache.
  2. #12
    May 2008
    If someone can help me build a custom pid I would just like to at least be able to log to the end of the map sensor voltage.
  3. #13
    Jan 2014
    this isn't completely true. The SAE pid is limited to reporting up to 255 as it is one byte(0-255). I believe the ecm can read in and perform math with up to 285.
    Is raw MAP voltage available as a scan tool item?
    If not you could run the map sensor into one of the analog in's on the V2- and scale it from there.
  4. #14
    Quote Originally Posted by RADustin View Post
    Hmmm interesting, I figured that 0-255 range = 256 unique values or 2^8 applied to both the PID and what the PCM/ECM can do. Be interested to know, even more so if this changes per ECM/PCM...
  5. #15
    Jan 2014
    its the way the packets come across the data lines. It doesn't have to do with internal PCM processing.
  6. #16
    What controller are you working with? The LS1 has a PID called 'GM.MAPBOOST_DMA', that will read past 255kPa. If you are talking later model ECM's (E40, E38 etc) then forget it, the ECM's internal calculations do not allow past 255kPa.
  7. #17
    Jul 2003
    Simple
    Create a custom PID with your sensor's equation and log map.voltage and custom convert.... also log VE table dma and you will know where you are .
  1. 3bar COS logging only to 255kpa
    By BAD BOB in forum FlashScan V2 BB Logging
    Last Post: June 28th, 2013, 03:01 AM
  2. reduced engine power after 3bar install
    By 9secVette in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 29th, 2006, 08:39 AM
  3. 3bar custom OS questions
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2006, 03:33 PM
  4. 3bar spark strangeness above 512 g/sec
    Last Post: October 9th, 2005, 10:56 AM
  5. Custom OS 3bar problem (need the experts)
    Last Post: September 12th, 2005, 04:10 AM
