Results 1 to 10 of 20
Thread: V2 unable to connect to scanner
    Nov 2013
    Default V2 unable to connect to scanner
    Hi,
    I am unable to connect to the scanner. I can read files, edit, & burn the files back into the PCM fine - just unable to connect to the scanner to do logging/dct's ect.
    When I hit the "connect" button in EFILive scan V7.5 I am getting the error...
    Error
    The FlashScan/AutoCal interface is not compatible with this version of EFILive software.
    Please install the latest version 8 EFILive software, then use the "EFILive control panel" program to update the firmware.
    I have a Flashscan V2 running Bootblock 2.07.06 / Firmware 2.07.51
    V7 5.7 (build 245) Calibration 713
    V8.2.2 Build 234
    Cheers
    Senior Member KhakiCummins's Avatar
    Sep 2011
    Looks like your firmware needs update. The latest firmware is V2.07.52
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Nov 2013
    Just tried to update but it says V2.07.51 is up to date??
    Nov 2013
    Anyone have any ideas??
    Can you post a screenshot of the V7 scantool doing that...
    Which PCM are you trying to connect to...?
    Nov 2013
    2003 Gen3
Name:	V7 screenshot.jpg
    Nov 2013
    Two more screenshots..
ID:	16128Click image for larger version.
    In the scantool go Edit->Properties->Connection and in the cable type select V2.5.
    Nov 2013
    V2 or V2.5 makes no difference. Comes up with the same error.
    Apr 2010
    Hi, I am having the exact same issue. Is there a way to load an older version of firmware until this is sorted? Cheers
  1. unable to get to cos 5
    By cb350rx7 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 11th, 2013, 10:39 AM
  2. Unable to get into systems with V2
    By Mayhem in forum Gen IV V8 Specific
    Last Post: January 12th, 2012, 01:27 PM
  3. Unable to lock
    By killerbee in forum Duramax LLY
    Last Post: July 13th, 2011, 04:50 AM
  4. Unable to see GM PIDs
    By Babydeuce in forum General
    Last Post: May 28th, 2008, 10:04 AM
  5. Unable to log
    By Telco in forum FlashScan V2
    Last Post: December 7th, 2007, 02:39 AM
