Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 157
Thread: Cummins 6.7L Overhead Chime Public Beta software
    Nov 2005
    Default Cummins 6.7L Overhead Chime Public Beta software
    UPDATED NOVEMBER 18, 2014
    ***Files now included in Oct 28, 2014 (or later) software release***
    Ross has spent a lot of time working through the 6.7L overhead chime issue. We had hoped to have a permanent fix publicly released before we left for PRI, but unfortunately we have run out of time. All is not lost, below is link and instructions to a public beta for these features which has been extensively tested by our beta testers and a number of individual customers who have contacted me over the last few months.
    To install these files, Customers MUST first update their V7 software, V8 software and firmware to our **REMOVED LINK**
    NOTE: PRE-RELEASE SOFTWARE is ONLY available via manual download. PRE-RELEASE SOFTWARE (if available) is listed on our DOWNLOADS page BELOW Public Release software.
    Before you install these files, you should know that these in this format MAY NOT become our permanent fix. There may be some slight changes between public beta and public release.
    These files DO NOT cover all OS's but here is the list of OS's the fix can be used on.
    11551035,
    11620807,
    11720809,
    11551031,
    11620604,
    11620606,
    11720604.
    Extract the zip found ***REMOVED, files now included in Oct 28, 2014 (or later) software release***
    Install the files over the top of your latest release software into the below folder.
    32bit Windows
    :\Program Files\EFILive\V7.5\Calibrations\CMC
    64bit Windows
    :\Program Files (x86)\EFILive\V7.5\Calibrations\CMC
    There are changes to be made in a number of places, the first is B7500 - see dealer reminder timer. Extend this to 360. (Timer is now set to chime every 6 hours).
    The second set of changes is under F2000.
    Below is a picture of the new tables
    It's hopefully self explanatory on how it works, just select 'Not Used' next to the DTC you want disabled. If you need to re-enable a DTC just select the correct P code from the drop down list.
    DTC's have multiple instances, so make sure you catch them all.
    If you want to quickly disable a DTC, just select the cell you want and press the letter 'n' on the keyboard rather than using the drop down list.
    One thing I would like you to keep an eye out for is a mismatch of P codes, eg, instead of it showing this:
    P125B "Power Enable Control Circuit High" P125B
    It might show this
    P125B "Power Enable Control Circuit High" P1096 << that would be wrong
    Cindy
    Last edited by cindy@efilive; November 17th, 2014 at 04:50 PM. Reason: Links removed
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    Cindy, I think it needs to be added that this is not a sure fire fix for the overhead chime. We are still getting it on several trucks, but the timer and enhanced code tables help to minimize the issues. It is still likely that problem trucks will still have messages with this software.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    May 2008
    well guess i'm gonna need a little help getting this to work? so how do I go about installing this over the latest V7 update?
    Yep ran the update a couple times I have the nov 7th and none of the tunes are showing the B7500 timer or the F2000 part either? I must be doing something wrong?
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Member Programmer's Avatar
    Oct 2013
    Hey, I'll try anything at the moment--thanks for adding this ! I think you're very close to a permanent solution.
    Dec 2012
    I know that this is wishful thinking...... But is this an update for 2013?
    Jun 2011
    Quote Originally Posted by CGASTON View Post
    2013 trucks are a whole different animal of an ECM I hear. Not good news.
    As in 2013 models? No it isn't, we haven't got the 2011-2012 done yet.
    Nov 2010
    Sure you can pay Bully Dog some ridiculous amount of money to open the ECM up, but nobody has hex editing for it yet that's stable...Ryan tried, but don't think it went well.
    While this update will kill the "See Dealer Reminder" dinging every 10-min it doesn't stop all the OHD chimes...so its a small victory.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Quote Originally Posted by comnrailpwr View Post
    Yeah, 2013 went to another ECM again.
    2006-2007 use a CM849
    2008-2010 use a CM2100
    2011-2012 use a CM2200
    2013+ use a CM2350
    Really, a two year life span on ECM's? GM gas cars still use the same ECM from 2006 to 2014 models on some engines.....and they went broke!
    Quote Originally Posted by 2007 5.9 View Post
    We still get mixed feedback Les, some people we've sent this out to have an all clear on all fronts.
    Nov 2013
    Under F2000, P0489 "egr control circuit low" is listed twice. Row #1 and 49. OS #11551035
  1. Cummins BETA..
    By 2007 5.9 in forum Do you want to be a Beta Tester?
    Last Post: November 11th, 2010, 05:04 PM
  2. Cummins software screenshots
    Last Post: October 12th, 2010, 10:55 AM
  3. Issue selecting Modules with latest public beta
    By Brian1 in forum FlashScan V2
    Last Post: October 11th, 2009, 10:38 AM
