I've had the F2000 since we got it in beta...most trucks are ok, but some still still show a catalyst full message.
We can look at it next year.
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
Do we have to redownload the tune to see the B7500 table. after the update it shows me B7500 cannot be found?
2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
1984 CJ7 powered by a 2000 LS1. 4L60E.
2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
2003 Jetta TDI,
1986 K10 LQ4/4L80E
Confirm you have an os supported by the files.
Parameters shouldn't go missing.
You shouldn't need to reopen the file, but we do recommend you build from scratch.
Cheers
Cindy
its a 11620807 did the download and made sure and for some reason its not showing up? is there anything else I could be doing wrong?
2003 Jetta TDI,
1986 K10 LQ4/4L80E
I'd run the install again, and double check that it's going to the right place. If you are still having problems, email me the tune and I'll take a look
cindy at efilive dot com
cheers
Cindy
Under F2000, P0489 "egr control circuit low" is listed twice. Row #1 and 49. OS #11551035
P0489 is listed several times in most OS. That code is a generic EGR code.
Les Szmidt
2007 5.9 Dodge Ram
Yeah, how it actually works (and this is what also makes it hard) is the ECM monitors items for failure, so in the case of the EGR Low, it might detect a short circuit on the wire or the output might have failed, two different problems but then the F2000 table is used to assign a failure to a P code. This is why you can end up with a number of instances of the same code and different items might cause a similar failure.
I've said to a few people that the programmers at GM/Delphi deserve a medal for how they designed the DTC reporting, Cummins and Bosch ECM's are pretty confusing for sure.
Hi. Where do you download the CSP5 beta for a diesel 2008 Dodge RAM 2500 with Cummins 6.7L ? Would the ECM have the same year 2008 as the truck ?
