Page 3 of 16 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 157
Thread: Cummins 6.7L Overhead Chime Public Beta software
  1. #21
    Nov 2005
    Quote Originally Posted by Leo Pardo View Post
    Hi. Where do you download the CSP5 beta for a diesel 2008 Dodge RAM 2500 with Cummins 6.7L ? Would the ECM have the same year 2008 as the truck ?
    There is nothing publicly available for CSP for 6.7L vehicles
    Cheers
    Cindy
  2. #22
    May 2008
    Quote Originally Posted by cindy@efilive View Post
    I'd run the install again, and double check that it's going to the right place. If you are still having problems, email me the tune and I'll take a look
    cindy at efilive dot com
    cheers
    Cindy
    I will do that when i get home this evening I have ran the update 4 times. twice i saved the update to my desktop and then ran it andwice I clicked on the link to run it. so far no luck, I must be missiing something somewhere. I ahve tried all of my tunes that have the Supported OS and no luck.
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  3. #23
    Nov 2005
    When you save the download to your desktop, open it. Copy the files listed then navigate to
    C:\ProgramFiles\EFILive\V7\Calibrations\CMC and then paste them.
    You will need to over write the files already there.
    Cheers
    Cindy
  4. #24
    May 2008
    Ok I'll see what I can do. thanks.
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  5. #25
    Junior Member KDubya's Avatar
    Jun 2011
    When you double click the cmc.zip file, that file will pop up in a different window with the files inside it.
    You will see the files inside a new window, over to the left there will be a link inside the box in that window that says "Extract All Files".
    Click that "Extract All Files" link, a dialogue box will pop up that asks you where you want to extract these files to.
    Browse to C:\ProgramFiles\EFILive\V7\Calibrations\CMC and then click "OK".
    At that point it will ask you if you want to replace the files already in the CMC folder, Click "Yes to All".
    Clear as mud?
  6. #26
    May 2008
    when I goto open the file that I have saved on the desktop by clicking "HERE" it just automatically goes through the normal efi live update tried right clicking to open the file and that has no option for unzipping.
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  7. #27
    Jan 2006
    2006-2007 use a CM849
    2008-2010 use a CM2100
    2011-2012 use a CM2200
    2013+ use a CM2350
    Should this read, 2007.5-2010 use a CM2100?
    Custom Tuning Services
  8. #28
    Junior Member dodgeram082500's Avatar
    Nov 2009
    I thought all the 4th gens 2010-2012 ran the cm2200
    2008 6.7 regular cab short bed 4x4 All mods by Terror Custom Tuning.
  9. #29
    Senior Member KhakiCummins's Avatar
    Sep 2011
    Quote Originally Posted by catman3126 View Post
    Is the file that you are trying to open called CMC.zip?
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
  10. #30
    May 2008
    Quote Originally Posted by KhakiCummins View Post
    Yep.
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  1. Cummins BETA..
    By 2007 5.9 in forum Do you want to be a Beta Tester?
    Last Post: November 11th, 2010, 05:04 PM
  2. Cummins software screenshots
    By GMPX in forum General (Diesel)
    Last Post: October 12th, 2010, 10:55 AM
  3. Issue selecting Modules with latest public beta
    By Brian1 in forum FlashScan V2
    Last Post: October 11th, 2009, 10:38 AM
