Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: E67_AFRATIO_DMA is not working properly ?!!
    Sep 2006
    calc_pids.txt
    Yes E10 for pump gas.
    Sep 2006
    I'll have to go make you a quick log file. I wasn't saving anything since I wasn't making any forward progress.
    Sep 2006
    2013 ZL1 E67 AFR Log.efi
    Short log file as requested. I can't thank you enough Joe.
    Try this calc_pids.txt...
    Sep 2006
    Thanks Joe, I'll give it a try right now.
    Sep 2006
    Looks Great! Local test drive appears to be perfect. I'll let you know how the dyno goes tomorrow. We can just start passing this file around to everyone else that needs it.
    Thanks again,
    Randy
    Randy,
    Yes, please pass it around to who ever needs it...
    but please tell them to use CALC.WO2BEN for tuning, and that CALC.FUEL.AFR is for viewing/info only.
    Sep 2006
    The tune went very well on the dyno and would not have been possible without your help! The air fuel dialed in perfectly. Thanks again Joe!
  1. E39_AFRATIO_DMA is not working properly
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 20th, 2013, 04:51 AM
  2. Properly logging MAF
    By ForcedC5 in forum Gen III V8 Specific
    Last Post: January 7th, 2013, 06:32 PM
  3. Cruise not working properly after tire calibration
    By Max Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 30th, 2012, 12:26 PM
  4. External flashscan inputs (EXT.AD1 & EXT.AD2) are not working properly!
    By TransAm-Z in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2011, 08:25 AM
  5. Why Can't I get my DSP 5 to work properly
    By Dr.Gixxer in forum Duramax LLY
    Last Post: May 4th, 2011, 05:10 PM
